Old 06-14-2023, 12:27 AM   #1
clutchkick
Drives: '12 2SS 6MT
Speed dependent whine - could it be rear diff?
Looking at a 2012 SS 6mt, car has a whine that changes in volume and pitch as speed changes above 35mph. Could it possibly be a diff bearing or something driveline related? Hoping it may be tires as it has 275/315 continental extremecontacts that have very little wear on them and was driving on relatively new pavement. Not really sure what it is, looking for advice on what could potentially be the issue as a diff rebuild would not be ideal.
clutchkick is offline   Reply With Quote
Old 06-14-2023, 09:01 AM   #2
fz4k98
Drives: 2013 1ss
If you can, drive it on different road surface type ( new, old, pavement, concrete etc) and see if it changes depending on road type which would be tires.
Can you determine if it is front or rear?
fz4k98 is offline   Reply With Quote
Old 06-14-2023, 09:03 AM   #3
gtstorey
Could be wheel hub bearings.
Old 06-14-2023, 12:02 PM   #4
clutchkick
Drives: '12 2SS 6MT
Not really sure if its front or rear, noise kind of fills the entire car. Good shout on the wheel bearings I hadn't thought of that. Thanks for the replies guys, will try to drive it on a different surface and hopefully get a better picture of the situation after the inspection is done.
Old 06-14-2023, 03:20 PM   #5
clutchkick
Drives: '12 2SS 6MT
You were right gtstorey, inspection revealed it was a drivers rear wheel bearing. Gonna be looking at DIYs for that right now lol.
Old 06-14-2023, 03:36 PM   #6
gtstorey
Pretty simple to replace. You do need a pretty big socket though.
hum, rear differential, tires camaro rear continental, whine
