Old 06-18-2023, 07:00 AM   #1
scottm078
Drives: 2013 Camaro ss 1le
Arh headers to npp exhaust question
I picked up a used set of arh headers. Does anyone know what hi flow cats I could use? Also do I need an adapter? I think the stock exhaust is 2.5 inches. The collector is 3 inch. When I look on summit I’m not sure what part number to get.
scottm078 is offline   Reply With Quote
Old 06-20-2023, 12:36 PM   #2
scottm078
i reached out to ARH but havent heard back from them yet. looks like the tsp ones would work. if i go that route how are you guys hooking up your rear o2 sensors. Catless is not an option. i need to pass a visual and obd2 inspection in NH.
Old 06-20-2023, 06:41 PM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I got mine from Stainless works/Stainless power, you can order from any company just need to match up the pipe size. With headers you need to get the rear o2 sensors either tuned so they are less sensitive or turned completely off. My Header set up came with the cats and the o2 bungs front and rear.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 07-03-2023, 12:12 PM   #4
scottm078
anyone know what catalytic converter would work?
Old 07-03-2023, 01:10 PM   #5
Joe.G
Joe.G's Avatar
You just need to order a Hi Flow that has the inlet and outlet to match your set up
Old 07-03-2023, 01:19 PM   #6
scottm078
I was looking at the texas speed ones pn: #25-TSP20103x2.5CatConn pretty sure those would work. i think the texas speed headers and the arh are the same size and shape.
Old 07-03-2023, 01:21 PM   #7
Joe.G
Joe.G's Avatar
They're are different size outlet options on certain headers, and inlets on exhaust. You need to verify.
Old 07-03-2023, 02:00 PM   #8
scottm078
the headers have a 3 inch collector outlet and the stock exhaust (npp) is 2.5. at least thats what ive read on the internet so it must be true. the tsp headers are slip fit and so arent the arh. I got the headers cheap so im just trying to find a way to get them on the car. thank you for your help btw.
Old 07-03-2023, 02:13 PM   #9
Joe.G
Joe.G's Avatar
I just looked on ARH site and they do say it's 3" out, they list cats as an option Texas speed is probably cheaper.
Old 07-04-2023, 05:15 AM   #10
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm sure the outlet on the headers are 3" and the stock exhaust on your car is
2.5" so, yes those TSP cats will work. And as far as your rear o2's go they either have to be on or off and with most aftermarket cats I don't believe that they will be sufficient for the ecm to work with a stock calibration so, you will need a tune to turn the rear o2's off.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
