Old 06-19-2023, 08:00 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Oil/filter for built engines
What you guys using for your aftermarket engines?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 06-19-2023, 08:23 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
ACDelco PF63E due to larger volume and filtering surface area. It does have the proper check valve in it too. As for oil... clean and change more often that one normally would. Depending on your clearances, you'll likely need something heavier like 15 or 20W. "They" say use higher zinc content.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 06-19-2023, 09:17 PM   #3
RupertPupkin
There's a lot of 63s but not so much of the 63E.
730whp: 630Trq
Old 06-19-2023, 09:46 PM   #4
dreksnot
dreksnot's Avatar
You want the E for this reason. I split buying a case (dozen) with a buddy.
Old 06-20-2023, 03:57 AM   #5
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
h
How about the pf63F.....better?
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 06-20-2023, 11:30 AM   #6
dreksnot
dreksnot's Avatar
The PF63F is "fleet-pack", meaning GM/AC-Delco ships 12 PF63E's in a case of 12 (what we did), with thin cardboard between them (NOT in retail/individual boxes to display on a shelf, etc.).
Old 06-20-2023, 12:57 PM   #7
jeff657756
Drives: 2014 SS 1LE
Wix xp and Valvoline vr1 10w30 conventional on a built 408
jeff657756 is offline   Reply With Quote
Old 06-21-2023, 08:00 AM   #8
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Valvoline VR1 and ACDelco UPF48R
johnnyb305mia is offline   Reply With Quote
Old 06-22-2023, 07:16 AM   #9
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
For a built high performance motor that you really want to keep track of, we offer a billet reusable filter that you can easily take down and inspected whenever needed to get a good read on the health of your combination. Sure beats cutting open canister filters!
https://gwatneyperformance.com/produ...en-v-lt/ref/3/
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-22-2023, 07:24 AM   #10
johnnyb305mia
I have seen these on the website. debating getting one. My thoughts on cleaning it is, w/o an ultrasonic bath, are you truly able to get it fully clean?
Old 06-22-2023, 07:24 PM   #11
RupertPupkin
I saw a similar item, and have always been curious of the longevity as well as how to clean it. Maybe dawn dish soap.
730whp: 630Trq
Old 06-23-2023, 01:17 PM   #12
acammer
acammer's Avatar
They clean with brake clean, carb clean, or dish soap. Good clean, compressed air, and ready to go for the next round.
Old 07-17-2023, 10:39 PM   #13
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Do these filter better than the reg filters ?
_Onyx_Wolf_ is offline   Reply With Quote
Old 07-18-2023, 06:27 AM   #14
acammer
acammer's Avatar
No - and that's not really the point of a reusable filter. The reusable filter gives you the ability to easily have a look "inside" the engine - you can get a good idea if you're producing any metal, what type, and what sort of volume, and all of those can be very important indicators for the health of the combination.
