Old 06-21-2023, 09:37 AM   #1
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
Window Re-Learning on a vert
I did the negative battery cable add on in the trunk. Does anyone know the process to re-learn windows on a vert? is it the same as a hardtop?
MSgt O is offline   Reply With Quote
Old 06-21-2023, 10:11 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I would think so. Give it a shot. Hold down button extra second or two before releasing and going up. If I didn’t hold for the extra seconds, didn’t seem to want to work.
0stones0 is offline   Reply With Quote
Old 06-21-2023, 10:54 AM   #3
MSgt O
MSgt O's Avatar
Do you need to do both drivers windows? or just the main one? Ive tried just holding the buttons, but not disconnecting the plug at the door, and it didnt seem to work.
Key off all windows up, door closed, turn key into ACC position, get prompt on DIC, main window down, hold for 4 seconds, main window up, hold for 4 seconds. and nothing happens. what am i missing?
Old 06-21-2023, 11:17 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Try all this I just found. Good luck, hope you get it fixed.
https://www.camaro5.com/forums/showthread.php?t=70683
Old 06-21-2023, 01:14 PM   #5
Blue 13
3P171 USAF Combat Arms
Blue 13's Avatar
Drives: 2013 SS/RS
Tim, mine asked after I reconnected the battery.
416ci LS3/Vortech V7/Built 6L80
996.6 RWHP 794.9 RWTQ
Blue 13 is offline   Reply With Quote
Old 06-21-2023, 01:36 PM   #6
MSgt O
MSgt O's Avatar
Mines asking. just not STOPPING asking....after I try the procedure. Do i need to close and open both front and back window? What am i missing here....and Wayne, Ive tried that first one, and its not working. Guess Ill try to unplug that connector and try again edit one more, do i need the top up maybe??
Old 06-21-2023, 03:25 PM   #7
Blue 13
Blue 13's Avatar
Drives: 2013 SS/RS
Tim, yes the top has to be up for the indexing to take hold so that’s probably why it’s continuing to ask even though you keep putting the windows up and down.
Old 06-21-2023, 04:02 PM   #8
MSgt O
MSgt O's Avatar
well shit....no wonder..thanks man!
Old 06-28-2023, 10:40 AM   #9
MSgt O
MSgt O's Avatar
yep....Top up and it worked!
Old 06-28-2023, 06:32 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome stuff!!! Glad you got it..
Old 06-29-2023, 07:03 PM   #11
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
On my 2015 it tells me which window in order
Mike J is offline   Reply With Quote
Old 06-29-2023, 07:55 PM   #12
MSgt O
MSgt O's Avatar
Funny, it only asked me for the drivers! all the others are working as well.
