Old 06-23-2023, 11:22 PM   #1
cc-rider
Drives: 2010 Camaro SS
Front main seal leak - ATI balancer
So now discovered that my freshly built motor has a leak coming from the front main seal. I’ve got the ATI dampener I put on. Did I miss something and those need some special seal?? I was very careful to let the seal center itself before torquing down the front cover bolts. This even caused a bit of a step between the front cover and the block. But I did use RTV along with my oil pan gasket.
Not sure what went wrong here. Anyone else have this problem with the ATI balancer?
cc-rider is offline   Reply With Quote
Old 06-24-2023, 03:48 PM   #2
bsn
Drives: 2013 ZL1
Is it possible you installed the seal backwards? If not the seal is easy to damage and needs to be installed dry no grease/oil on inner seal surface, no sealer on outer surface. If anything the finish on the ATI balancer is better than factory.
bsn is offline   Reply With Quote
Old 06-24-2023, 07:40 PM   #3
cc-rider
I definitely didn’t install it backwards. My 3rd LS build and I’ve never had any problems. I know they need to be installed dry too. I wonder if I somehow got some lubricant on there accidentally. It’s the only thing I can think of.
