Old 06-24-2023, 01:14 PM   #1
booboo37
booboo37's Avatar
Drives: ls3 Mustang
Garage sale
L8T 6.6 steel cranks ....Great stroker cranks for Ls...Lsa....Ls9.... These are the better steel cranks found in the newer 2020-2023 gas Silverado and GMC HD trucks.......one barely needs polished $475 plus shipping .........one don't need polished....$525
3.860 stroke
58x crank trigger
8 bolt flywheel pattern
Center counter weighted design
Make a 8,000rpm Ls engine..
Guys are using a 6.2 long rod and a common piston for 4.0 stroke and 6.125 rod to end up at zero deck height ........
These are 60 lbs with the heavy duty crank box....can ship but not cheap........or pick up Mi. 48240
Also have 823 rectangle port heads with new Gm L92 valves........no springs...should be milled.......Sold !
Also have fresh Lingenfelter Ls7 long block stroked to 442ci +.005 bore.....with New Prc 265 Ls7 heads,,,flow 393@700,,with 700 lift springs,,, New Callies Dragonslayer crank, New K1 rods, New Wiseco pistons 11,6.1cr....stage 4 camshaft, Johnson lifters, Trend push rods, coated bearings,,,,,,, $12,500 firm..Long block.....not shipping.....pick up 48240..........or this can be bought with my clean mini tubed 68 Chevy ll $55k
Cranks are 60lbs with the crank box........from 48240....Paypal only
booboo37 is offline   Reply With Quote
Old 09-18-2023, 08:48 AM   #2
booboo37
booboo37's Avatar
Drives: ls3 Mustang
Pictures posted and updated post.....Sept. 18
Heads sold...
Old 09-29-2023, 05:41 AM   #3
booboo37
booboo37's Avatar
Drives: ls3 Mustang
Lowered prices......Sept. 29
