06-26-2023, 11:12 AM | #1 |
Drives: Chevrolet Camaro RS Join Date: Jun 2023
My Son's 2017 RS Pull Me Over
I purchased a 2017 RS for my son from a reputable dealer in South Florida with 14,000 miles on it. It now has 53,000. The vehicle is stock. We are feeling a vibration, rumbling, shaking, or hesitation at low RPM (1500 - 2000) regardless of the speed. Does not occur during automatic shifting. Happens temporarily and then quickly goes away. Even occurs on cruise control at 70 MPH. This is not an everyday occurrence, but intermittent. No check engine light. Ran a code at Autozone which showed something about Transmission Fluid Temperature Sensor which may or may not have anything to do with the vibration, rumbling, hesitation problem we are experiencing.
Does anyone have and thoughts or ideas on how to diagnose the problem and intervene with a fix? Last edited by basswilliamb@yahoo.com; 06-26-2023 at 11:14 AM. Reason: Spelling |
06-26-2023, 11:30 AM | #2 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
A8 shudder?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
06-26-2023, 11:38 AM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
06-26-2023, 12:14 PM | #4 |
Monterey County Camaros
Likely shudder. Sounds like what my car was doing. Do a transmission flush. Should fix it.
Follow us on Instagram @montereycountycamaros
06-26-2023, 01:19 PM | #5 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
+1 on the previous posts, look up the TSB referenced above and head to a service department for a complete flush using the latest Mobil1 transmission fluid.
If this isn't a very frequent occurrence, chances are you can still save the original torque converter.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
06-26-2023, 01:53 PM | #6 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Another "A8 shudder" reply.
Glad I convinced a dealer to flush mine under warranty before it hit 1000 miles.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
06-26-2023, 02:28 PM | #7 |
Thanks guys, you're the best. I even did a search on CHATGPT and came out with some other recommendations but the TSB 18-NA-355, and A8 shudder I believe are more likely than the solution Artificial Intelligence (AI) found. Will try the completeTransmission Flush with the latest Mobil 1 Transmission fluid and report back to the forum when completed. Much thanks again!!!
06-26-2023, 06:16 PM | #8 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
I hear only 5% of A8's had probs. But that is all i see on the forums is shudder and this and that. I had it at 400 miles on a new 2019 C7 and now have a 2015 C7 that has never been touched and no shudder ever.
06-26-2023, 08:42 PM | #9 | |
I had all available mitigating measures applied, including a proper tune, and never had the issue, my A8 works exceptionally well—this debacle is such a lost goodwill opportunity for GM, the 8L90 is a very good transmission that lost its initial great reputation entirely due to this stupid mistake. One thing I've always wondered is if the 10L90 would shudder the same way if the same bad fluid and tune were used with it. We will never know, of course, but it's not an altogether different unit from the 8L90, nor is it a ground-up brand new design.
06-26-2023, 09:25 PM | #10 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
if the shudder is strong enough that people other than the driver with their foot on the peddle can feel it, it might be too late for just a fluid replacement to fix. the torque converter gets glazed during these slip events and becomes permanently damaged over time. you have to do the change at the early onset, otherwise you have to do a fluid change + new converter.
make sure you get the good fluid when replacing. blue label, not black if using mobile 1. anyone driving with fluid pre 2019 should change their fluid even if you don't have a problem. the issue in many environments is just a matter of time because it's due to the bad fluid used before 2019 that attracts water and the trans not reaching operating temps to boil it out over time. |
06-27-2023, 05:13 AM | #11 |
A8 Transmission shudder and P0700, P0711 code which is a broken ribbon cable in the Transmission that is the temperature sensor cable And hopefully it did not do enough damage that it hurt the torque convertor. Let us know what happens.
06-27-2023, 07:57 AM | #12 | ||
Drives: 2016 2SS Convertible Join Date: Dec 2019
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
06-27-2023, 11:30 AM | #13 |
Don't tread on me
Drives: 23 Sierra X31, Past 2017 Fifty 2SS Join Date: Nov 2012
Yup A8 shudder. I've had several GMs with an A8 and they all do it at some point. Tranny flush will fix it.
06-27-2023, 10:41 PM | #14 |
Drives: Camaro RS Join Date: Oct 2022
My 2018 RS has 46k miles and just started the shutter last week. Maybe the Louisiana heat and humidity of the last two weeks finally got to it? Went to a well respected transmission shop who dropped the pan, changed the filter and put all new fluid. They told me that the magnet at the bottom of the pan did not have any metal on it at all. So far, the car is driving good, without the shutter.
