Old 06-26-2023, 07:28 PM   #1
DarkkneZPanda
DarkkneZPanda's Avatar
Drives: 2014 LT Chevrolet Camaro
Jet Performance Throttle Body
Hey everyone, thinking of getting a new throttle body for some fun and better throttle response. Does anyone have experience with this?
https://jetchip.com/shop/throttle-bo...tle-body-copy/
If so, any expectations or any problems I should know before buying?
DarkkneZPanda is offline   Reply With Quote
Old 06-26-2023, 09:14 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
The factory TB is 72mm too so I gotta think you wouldn't see much more airflow. May be better off with the ported factory TB which is 76mm but not sure if it's still available. There is also an 80mm option from Overkill but seems he's been MIA for awhile now; not sure if anyone else sells the 80. Personally I wouldn't spend $400 on a TB that's the same size as the factory one but that's just me.
KillboyPowerhead is offline   Reply With Quote
Old 06-27-2023, 12:02 PM   #3
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
If you are looking for Throttle Response. The JMS PedalMax is you best bet.
Sales@Phastek is offline   Reply With Quote
Old 06-27-2023, 02:07 PM   #4
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
I have a Jet Perf. TB. Nice unit. I needed something "new" when I bought the car. I payed around $200 for it. I also have a JMS PedalMax but I haven't installed it. I'm working thru some other-things first for the car.
Sorry I wasn't much help.
DRC69 is offline   Reply With Quote
Old 06-28-2023, 01:34 AM   #5
DarkkneZPanda
No worries. Has it caused you any problems at all or has it run smoothly for you?
Old 06-28-2023, 01:36 AM   #6
DarkkneZPanda
I was looking into many options even from the 80mm Overkill but this was all I could find in something similar.
Old 06-28-2023, 08:35 AM   #7
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
Soler Performance has quality units. Running one myself
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 06-28-2023, 11:36 AM   #8
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Thumbs up
NO problems at all. Perfect.
