![]() Drives: 2010 2SS/RS Join Date: May 2010
TR6060 reverse back up light switch???
Has anyone here ever had your TR6060 reverse back up light switch go out and stop working??? My Gen5DYI reverse camera stopped working after we did the AGP TT install. The reverse light does not come on either.
Could it be the switch???? Also do I have to drain the tranny to replace the switch?
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
If you are worried about fluid coming out while replacing the switch, put a vacuum over the opened fill hole when you go to actually pull the switch and put a new one in. Little to no fluid will come out. An extra set of hands would help.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
