Old 07-07-2023, 08:39 AM   #1
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
Driver's door trunk release not working FIXED - OPERATOR ERROR
So where do I start looking for an issue? It worked fine before the battery/alternator crapped out, but when I tried to use it the other day - nothing. I had to use the trunk release on the remote.
Any ideas?
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 07-07-2023, 09:01 AM   #2
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Mine sometimes takes a few punches before the trunk unlatches. I figure a funky contact in the switch but haven’t done any investigation yet.
ADVMax is offline   Reply With Quote
Old 07-07-2023, 09:05 AM   #3
DonM
Camaro #4
DonM's Avatar
I'm not TOO worried about it at the moment ... at least not until my remote falls apart like the last one
Don M
Old 07-07-2023, 12:49 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have to do the same here as you. Not a problem as of yet.
Old 07-07-2023, 02:18 PM   #5
SlowLS1
SlowLS1's Avatar
A small squirt of regular old WD40 will fix that button. After applying WD40, work the button about 20 times. Cleans of the contacts and frees up contacts.
SlowLS1 is online now   Reply With Quote
Old 07-08-2023, 04:02 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Switch was bad on mine. I just pulled the panel and replaced it.
Old 07-08-2023, 08:49 PM   #7
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Switch bad on mine too..plucked it out without removing door panel…tight fit ..switch is separate from bezel
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 07-09-2023, 01:18 AM   #8
DonM
Camaro #4
DonM's Avatar
It's working now. Either *I* forgot to FULLY depress the button - OR - I forgot to hold it in for a quick second.
Don M
Old 07-09-2023, 08:39 AM   #9
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
I did this too. The lead is short.
Whoomba is offline   Reply With Quote
Old 07-09-2023, 10:34 AM   #10
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I tried pulling out my switch with a plastic trim removal tool and for the life of me cannot remove it. Looks like the door panel has to come off on my end. How did you do it?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 07-10-2023, 07:35 AM   #11
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Get a new car battery and thank me later for saving you tons of time.
Car Nation Videos is offline   Reply With Quote
