![]() ![]() ![]() ![]() ![]() Drives: 2023 ZLE Join Date: Jun 2009
Oil for ZLE Track Use
How many of you guys tracking ZLEs are using Mobile 1 15w-50?
![]() Drives: 2021 ZL1 1LE Join Date: Aug 2010
I do. That is all I use for track days. Have 45 track days on the car with no issues using that oil.
#3 | |
![]() Drives: 2019 ZL1 1LE Join Date: Jul 2022
That seems very impractical, time consuming and expensive. |
#4 | |
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I change to 15W-50, sometimes a week or 2 before the event, run the track, and change the oil when I get home. If you do 2 full track days, the oil needs changed again anyway. |
No. I run 15w-50 in my car all the time. I track the car more than drive on the street. As long as you don't rev the car when the oil is cold you won't have any issue running 15w-50 all the time. I have had the car two years purchased new and currently have right at 9,000 miles on the car (7,000 miles track). No issues.
#6 | |
PS - This 23 replaced an 18 and I’m surprised how much higher the oil pressure reads on the gauge on the 23. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I use Motul 300v 5w40...oil temps on track are 15-20 degrees more with 15w50 due to the oil pump working harder to pump that thick syrup. The fact GM hasn't really nailed down a perfect viscosity recommendation leads me to just about anything will suffice. 5w40 Valvoline MST used to be an approved oil for the LT4 and now 0w40 is the factory fill when 5w30 was factory fill in 2017...so WTF? Nothing is perfect and use what makes you happy...remember even the recommended 15w50 for track use isn't Dexos certified.
#8 | |
#9 |
![]() Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
One thing that I have not been able to find is the relative viscosity difference between 0/40 and 15/50 at operating temp. Obviously 50 is more viscous than 40, but at operating temp on track (say 240) what’s the exact difference in viscosity? Is it material? Does anyone have insights with some data on this? Thx!
#10 |
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
I have switched to the new SuperCar 5w50 (for my Katech SS 1LE).
I did run 15w50 in my ZLE, year round (AZ weather). Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
#11 |
![]() Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
15w50 all the time (Georgia) - 8,000 miles track / 20,000 miles total
#12 |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
Nope. Redline here. Way more moly and protection.
#13 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
15w-50 here mostly to all year. I saw oil analyses on bobistheoil.com with some LT4s with mixed street/track with 15w-50 and results were fine. The one thing I don't like is carbon coking on the dip stick.
19k miles on car, about 9k track miles. I use Motul 300v 5w-40 otherwise and the engine seems to like it. Its a thicker 40 grade with ether oil base.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
#14 | |
In theory xw-40 should run cooler due to the reduced fluid friction mentioned above. GM recommends the higher viscosity oil for cornering protection, then only for the ZL1 1LE.
