Old 07-12-2023, 09:14 AM   #1
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
Summit White Owners Question
Do any of you have on the top of your front struts, a discoloration, almost like toasted marshmellow color? Mine has been like that from the day I bought it, and I cannot find any reason as to why. I would think heat, but cant see anything that would get that hot in that area!
MSgt O is offline   Reply With Quote
Old 07-12-2023, 09:46 AM   #2
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Yeah, my car has this. Definitely looks like a burnt marshmallow.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181
2011 Camaro 2SSRS - Sold
No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars!
The_bald_eagle_machine is offline   Reply With Quote
Old 07-12-2023, 11:41 AM   #3
MSgt O
MSgt O's Avatar
Thanks! Just wanted to make sure it wasnt just mine. Wonder what caused it?? any thoughts?
Old 07-12-2023, 12:03 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Are you talking about the top of the strut towers? If so, when you drive your Camaro the struts will move up and down and around a bit in the opening where they go down inside the fender, and in doing so the rubber "grommet" or cushion or whatever you want to call it will sometimes touch the top of the tower under it and "discolor" it to make it look "burnt" where it rubbed. No big deal and they are designed that way to do that. So I have read on here in the suspension section.
Old 07-12-2023, 12:15 PM   #5
Anthony S
That pretty much sums it up. Only real solution would be to buy some camber caster plates, which will mount your front struts in a fixed position. But for a daily driver it isn't really necessary. I also see little bits of rubber up there too. I think its jsut part of the design and us folks with white cars just gotta look at the discoloration. My car has all new coilovers and isolators and it actually got worse when I changed everything out.
Old 07-12-2023, 12:24 PM   #6
MSgt O
MSgt O's Avatar
good to know! Thanks Wayne! and Bald what coilovers did you go with?
Old 07-12-2023, 12:26 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeppers. No way around it except like you said, caster/camber plates, but on a daily streeter, not needed. My Camaro being RJT, and the strut towers NOT being finished painted and cleared from the factory, I also have that ugly burnt look where the rubber rubs on it from time to time.
Old 07-12-2023, 12:32 PM   #8
MSgt O
MSgt O's Avatar
huh! so its not just a white car issue! Thanks!
Old 07-12-2023, 12:43 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir! Very welcome! And no on your other reply, it's not just a white car issue. Mine has been like that for a long time! And I have noticed other Camaros with the "burnt ring". lol.
Old 07-12-2023, 01:52 PM   #10
Anthony S
BCRacing Coilovers I got them direct from Phastek with a discount. I installed them straight out of the box and the car rides great. Decent price for coilovers and excellent ride quality. They have 32 adjustment "clicks" so you can make it ride like stock, or like a racecar with just a few clicks of the adjustment screw. I love them, and honestly wouldn't go back to the coil/strut design.
Old 07-17-2023, 09:19 AM   #11
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
You may want to check out the toilet mod to eliminate the gap.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 07-26-2023, 08:11 AM   #12
Ck1984
Drives: 2015 camaro LFX V6
ARE THESE MOSTLY TO CHANGE RIDE HEIGHT?
wether it be for looks or lower center of gravity and better cornering G forces
or are the shocks better than stock too
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
