Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > ZL1 Parts
Old 07-20-2023, 05:41 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
Hello, I need rear zl1 bumper/diffuser small parts and hardware
Hello, I'm looking for the Zl1 small brackets and hardware for the Zl1 diffuser. The hardware is not so important. And I need the driver side metal heat shield that goes around the exhaust tips. I'm looking at the rear bumper parts for a upgrade to my 2010 ss. I attached a diagram below showing what parts I'm looking for. Looking to do a secure transaction for both parties. Thanks, Dan
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 07-23-2023, 09:16 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Looking for the same but GM has discontinued the majority of everything.
Orange Krush II
Old 07-23-2023, 10:44 PM   #3
lionssfan
lionssfan's Avatar
I'm going to fabricate my brackets. I was able to get all the main parts. but yes parts appear to be getting scarce. The toughest part it seems right now is getting the dual exhaust tips on my Corsa Exhaust sys. I might do a youtube video on the install
2010
Edit Signature
Old 07-24-2023, 02:02 PM   #4
lionssfan
lionssfan's Avatar
most important part I need right now is the driver side heat shield for the diffuser. anyone have one? thanks Still could use related hardware. brackets for diffuser
2010
Edit Signature
