07-25-2023, 07:06 AM | #1 |
Drives: 2014 2ssrs Join Date: Nov 2015
Lift pass’s or Jack pads from zL1 addons,
What have you used and how well did they work. Did they require modifications to the car? I’m wanting to get a set but not sure whether to try the magnetic ones that are machined down to fit over vert. Bracing or try the stealth permanently attached ones because I’m not sure they need to be modified to fit over the vert Bracing. Thanks in advance
Last edited by Futuramic88; 07-26-2023 at 08:05 AM. Reason: Spelling,wanted subject to say pads not pass thanks auto correct! |
07-25-2023, 11:08 AM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I have the magnet ones, they work great. I also have a rubber set that works good too and they are way cheaper.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
07-26-2023, 08:13 AM | #3 |
Thanks tartagliazl1I ordered a set of stealth lift pads after talking to Addons phone rep.He said they will fit. Let you know if they do. Fingers crossed
07-29-2023, 09:57 AM | #4 |
Drives: 2011 RS/2LT- manual Join Date: Aug 2021
I bought the bolt on lift pads.
07-30-2023, 11:34 AM | #5 |
Drives: 2013 Chevrolet Camaro RS/2LT Join Date: Jun 2022
Lift pads
Mine look like the same construction as the zl1addons but are just black from Amazon. Are 6061 Aluminum alloy as opposed to billett but should easily be strong enough for half the price. In the process of modification for them to fit. Cutting about 1/2 inch of lip off the extra brace on the convertible should do it.
07-31-2023, 05:23 AM | #6 | |
07-31-2023, 12:57 PM | #7 |
I bought these as well because they pretty much matched my RJT color.
07-31-2023, 01:29 PM | #8 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Did the exact same thing for the matching
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
07-31-2023, 01:33 PM | #9 |
07-31-2023, 07:47 PM | #10 |
lift pads
The red definitely looks good. Just put ACS splitter and sides on my vert so they can't be seen anyway. Just cutting the tab didn't work so I had to get the chop saw out. Went ahead and painted the bar orange although does not match the inferno orange of the car. Needed something on the cut metal. Dremeled off one side of the bolt flange too.
08-01-2023, 09:01 AM | #11 |
ZL1 stealth pads
Has anyone modified the lift pads to fit around the convertible bracing ? I would rather not cut the brace itself. Any one know what the ZL1 stealth pads actually are designed to lift on ? Is it the center cut out of the pads that contact the pinch weld only, or do the sides of the pad also contact the rocker panel as well? Thinking maybe a nylon shim on the outboard side of the pinch weld attached with 3m tape may distribute the load better. Someone with a coupe could probably shed some light on this question.
I certainly appreciate everyone’s comments so far. Thanks! |
08-01-2023, 06:52 PM | #12 | |
08-01-2023, 06:52 PM | #13 | |
08-02-2023, 06:12 AM | #14 |
Thanks, I’ll try that
