![]() ![]() Drives: '10 T/A Conv, '10 2SS, '77 SE T/A Join Date: Dec 2015
Help -Whipple Issues & Fuel Pressure Port
Really would appreciate help from the Forced Induction Heavy weights on this maddening issue.
I am trying to root cause my start and die issue on my 2010 SS Whipple & Cam set up. Developed this condition where the car is difficult to stay running after start-up, and can crank 2-3+ times before it stays running. I have a heavyweight well known tuner from this web site analyze many Data Logs and revise my tune, it is better, but still has the issue, especially when hot. He say's it can't be "Tuned Out", and is probably mechanical. When it runs, it really rips, but lot's of back rap and popping with the Long Tubes and Borla Atak w/o Cats. Normal? - I don't mind it. Back Ground - new TB, Accel Pedal, New fully charged battery, new tune. No Codes! Drained the old gas and put in fresh 93 Tier 2 - used a ingenious procedure I found on this site to do this. Kept pumping fresh gas into old gas over a number of years as the car is basically infrequently driven (car shows, a romp, etc.) My Tuner said disconnect and bypass the MSD BAP, which I did. Used MSD View software to analyze it and it seemed to function OK, but bypassed it to rule it out. IAT readings seemed high, ranging from 61 deg cold to 118+ at hot idle. Insulated the CAI Air box some more, and wrapped the inlet tube. Inlet tube was warm and blower hat was hot after a drive - normal? What I am doing now - checking and cleaning all grounds, wire harness integrity, connections, etc. Looking for the obvious. The car is immaculate and not like there is a lot of corrosion anywhere. My tuner said to check if my injectors were leaking. Getting a fuel pressure tester to do this. Is the FP Tap Port on the Whipple Fuel Rail as shown in the attached pic? Just connect to that, key it, and look for leak down over time? Possible Root Causes: 1. Bad Injectors leaking causing a hard start and excessive back rap/pop on decell? 2. Intermittent Fuel Pump issue? Did the MSD BAP not play nice with the FP? 3. Intercooler Pump intermittent? Seems to flow when looking into reservoir, but noticed the ground wire connection at the terminal was not in the best condition. 4. Bad Ground(s)? 5. WTF Else to check? Appreciate any insight and recommendations! |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
My money is on bad grounds. Check the back of the cylinder heads there's a ground on each head for each bank of injectors
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Are you on the stock fuel system with just the BAP? My return style system does not hold pressure when the pumps are off.
You should be able to use the port you show for testing pressure, but be careful when you pull out the plug. Also, if you are on HP Tuners, you can monitor fuel pressure with that. Edit: I'm not on here as much but feel free to message me questions. Sent from my Pixel 5 using Tapatalk
Stock Pump with (or currently disconnected) MSD BAP.
That port worked great to attach a Fuel Gage. I think data says I don't have injector issues, or do I? 12 lbs in a hour, 58 to 46. |
![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Dec 2006
No. That leak down test is normal. That’s why your pump primes when you turn the key on after it sits for a while (but it doesn’t prime every time you turn the key on). Normal for fuel pressure to leak down over time. Note that with a larger return style pump like I have…the fuel pressure leaks down to zero almost immediately. And it still starts ok. The fuel pumps can prime the system enough to start very quickly. I’ll also say that I think your running a bit dangerous with a stock SS fuel pump with your set up. I would at least put in a ZL1 pump and get the FPCM tuned to make the most of it. Though this has nothing to do with your starting issues. Just might take out your motor under big boost pulls if it can’t keep up! Lastly, I also highly doubt the BAP is any part of the problem here. They only kick on under boost.
Have you checked all your potential source of air leaks / vacuum leaks? Note that I have a Kenne Bell and a cam as well. Mine starts a bit more difficult when hot too. My guess…is it’s all in the tune. I saw your post over at HPT as well (I tune myself as well). You may want to consider paying one of those guys over there for a full on tune. I bet they would fix it. They are helpful over there…but they withhold some of their tips and tricks. Which I can’t blame them. |
#6 | |
So at this point - any recommendations on a return less setup? Difficult installation? I am well versed is wrenching so it is something I could complete, and maybe put this maddening issue behind me. Last edited by hesster; 07-29-2023 at 06:31 PM. |
#7 |
What is an "Accel Pedal"?
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#8 |
You may very well be getting some sort of vapor lock going on in the rails from all the heat. The superchargers are massive heat sinks and certainly put more heat to the rails than the plastic stock intake would.
I went with the AGP twin pump set up. Pretty good overall. I’d recommend it. Also, you can relocate the stock fuel pressure sensor from back at the gas tank to the under hood fuel pressure regulator when switching to a return style pump. Then you can still monitor fuel pressure within HP tuners. |
#9 |
Have been methodically going thru every ground I can access. Some are buried, and very difficult to get to, especially with a Whipple and it's plumbing. Expect to get "Hamburger Hands" reaching into places not meant to be accessed with big hands. Attached a compilation of ground locations for the LS3 and L99, and a great reference for the general location where to look. Most so far have been in good shape, but not like the one in the attached pic. It was down on the drivers side attached to the middle of the inner frame rail. And in the last attachment pic, that folks is where the large engine ground wire attach's to - right on the E-Coated ECM bracket. Really GM?
#10 | |
