Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
Camaro in storage…Battery?
I’m looking to purchase a Camaro and where I’ll be storing it there are no outlets. How easy is it to remove and replace the battery so I can trickle charge it?
Thanks
It don’t come easy.
Open the trunk, remove the spare (if it has one). Remove the cables and battery hold-down. Out she comes. Nothing drastic.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Just don't close the trunk when you're done or you'll have to let the back seat down and then get a child to crawl through the tiny opening to pull the handle to open it back.
#4 | ||
Thank you. The Vette is much more difficult.
#5 | |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Alternately, you can install a disconnect like this one. And yeah, prop the trunk open or you'll need 12v power on the jump posts under the hood to push the button. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
If possible, I'd look into an inexpensive solar powered battery maintainer. Might be less hassle than removing the battery...I've never used one, but they may be worthwhile....Good luck.
#7 |
Remove the carpet, remove the battery well cover, it's held down by a big plastic knob, under there you will find a foam liner with an air pump, a can of fix a flat, or a spare if someone has updated that, remove it all, then disconnect the cables, hold down bracket, and you're done.
