Old 07-31-2023, 01:29 AM   #1
camaro_nos
Drives: camaro ss 2010
nitrous plate
hi
i have new nitrous system
https://nitrousoutlet.com/i-30560016...te-system.html
the plate size is 102 mm
and my intake and tb is stock ls3 ( camaro 2010 )
So it will not fit .
i asking for link plate working with my nitrous system and my setup ( stock ls3 intake &tb )
i find this but i need to be sure
https://nitrousoutlet.com/i-30560097...-fittings.html
camaro_nos is offline   Reply With Quote
Old 07-31-2023, 07:18 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
That 90mm plate should work fine with the LS3. IIRC, when I installed my NX one I had to flip the TB for some reason, extend the plug and ditch the engine cover, well I notched the cover and ditched it when I went turbo.
Old 07-31-2023, 05:52 PM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Yeah, got to rotate 180°. The plate sandwiched between the intake and tb, extends the tb to the front of the vehicle. The actuator on the tb then hits the pulley, thus the flip, iirc.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 07-31-2023, 06:02 PM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Originally Posted by camaro_nos View Post
hi
Nitrous Outlet used to have Camaro specific setups, I believe they still do. Contains all the basic items needed. TB wire extension, pressure safety switch, fuel rail adapter, controller, solenoids, pre-bent lines, etc. Contact N.O. They have great customer service. Since it's new, I'd send it back and get the correct kit. Unless it's a "new" unused kit bought 2nd hand. If so, you'll need that plate and then piece together any other components needed. I've had my N.O. for about 10 years, no issues. But mine's more than the basic kit.
