Old 08-03-2023, 09:10 PM   #1
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
Leaving boost - tune downgrade question
I am going back to N/A. I have a 416 stroker with a single turbo at 8psi.
How hard can I drive the car before I get a new tune? Would it damage it or just run too rich or will the MAF adjust the tune based on lack of boost?
I have HPTurners pro, do they have public tunes after login, for a 416 stroker n/a?
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 08-04-2023, 08:41 AM   #2
gtstorey
You can probably drive it easy but I wouldn't drive it hard. But it can be hard to say since there are multiple ways it could have been tuned to start with. It might be in speed density and the maf isn't doing anything.
HPT doesn't have anything but stock tunes unless you find something on the HPT forum that someone has posted.
Old 08-04-2023, 10:14 PM   #3
SeaCompiler
Thanks. I think I will just go back to Vengeance and let them give me a tune update. I wasn't sure how much of a difference it would make exiting a boosted car. I know it matters going boosted.
