![]() Drives: '14 Red Hot RS/SS 1LE Join Date: Aug 2012
Looking to replace my OEM Tires
my OEM goodyears are nearing need for replacement and now that they are discontinued, what are people running? I don't track it and drive it only from April to October in the upstate NY
Continental Extreme Contacts. I have a friend on this forum who lives in NJ and he is running them and loves them. I run them as well, have for a long time. His name on here is "joekono".. You could send him a message asking about them.
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
On my Z/28 I installed Michelin Pilot Sport 4S tires and they work GREAT on the street, especially if you like to hang corners (like you should!) with your 1LE.
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2015
Either Continental Extreme Contact O2's or Michelin Pilot Sport 4S's. They will both perform really well in the summer weather with decent wet performance and they will last anywhere from 10-20 K miles but most folks don't drive these cars, they stare at them.
It don’t come easy.
I’ve been on BFG G Force for a couple years now and really like the handling and wear life. Same scenario, March to November, kinda thing.
#6 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Continental
#7 |
![]() Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
Michelin Pilot 4S
#8 |
Tri-County Camaro SWFL
Pilot 4S
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I found a New Set of the OEM Goodyear's, I really do like these tires the way the handle,ride and look. I am probably going to switch to the Pilot sports when the time comes, I do wish they would come out with a good looking tire that performs because I think the 4S is a boring looking tire.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#10 |
I just put on some Yokohama Advan Apex tires on my 1LE which does some work on the track.
They are one of the best sets I have used. On par with the PS4Ss I had on a couple years ago, but for less cost. They are great around down and really come into their own on track. I have been pleasantly surprised by them!
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
#11 |
Trawz , Do you have Pic's of them on your car?
These https://www.tirerack.com/tires/tires...e=035YR0V601XL
#12 |
Here is what I have.
2013 1SS/1LE
#13 |
They look good, ride smooth and quite?
#14 |
