Old 08-06-2023, 08:44 PM   #1
Ck1984
Drives: 2015 camaro LFX V6
New CatchCan Install with Vacuum leak
So i installed a new catchcan and immediately noticed a minor vacuum leak on that side.
Not enough to affect idle but noticeable to the ear.
I retaped and , reinstalled all the connections, no change.
Replaced the soft vacum line with steel braided fuel lines, no change.
-it goes away if i just isolate the entire catchcan and plug hose before the catchcan.
-it goes away if i hook up catchcan and plug in hole to catchcan
-BUT soon as i hook up the last hose that goes to pcv valve and valve cover, theres constant vacuum leak
Im now think its coming from the valve cover somewhere.
is carb cleaner the best aerosol based spray that will evaporate without residue to diagnose the leak?
any other ideas where to check or how to fix?
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 08-07-2023, 07:13 AM   #2
SlowLS1
SlowLS1's Avatar
Could it be resonance in the catch can you are hearing?
Carb cleaner works fine, stating fluid works well also.
Can you post a pic for us to help you better?
SlowLS1 is offline   Reply With Quote
Old 08-07-2023, 07:50 AM   #3
Ck1984
HAHA, it could very well be JUST RESONANCE as you call it, that would explain why i cant narrow it down with my ears or fingers etc
BUT i will confirm with carb cleaner /starting fluid anyways.
THEN post a pic if i dont find any real leak.
2015 2LT LFX 3.6L
Old 08-07-2023, 10:50 AM   #4
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Probably resonance. If you move the hose while idling you may hear the resonance change. I twisted mine and retightened to change the pitch.
Lacpac is offline   Reply With Quote
Old 08-10-2023, 12:09 PM   #5
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
I was just about to ask how you identified the leak, because my catch can setup makes a noticeable hissing noise w/o any leaks. Just the air passing through the hose I'm told.
ElderJ is offline   Reply With Quote
Old 08-10-2023, 12:26 PM   #6
Ck1984
yes thats exactly what mine does, general hissing sound in the area.
OH well at least i can be sure all my connections are good now having double checked them all and maxxed out the plumbers tape i could squeeze on all the threads.
2015 2LT LFX 3.6L
