Old 08-07-2023, 01:07 PM   #1
H8Rain
H8Rain's Avatar
Drives: Chevy Camaro 2SS
Need Engine Advice
History: I have a 2011 Camaro 1SS LS3. Fair weather car, no track.70k miles. Last year I installed a Whipple SC. Whipple provided the tune for my car. No other mods except Borla exhaust. For the past year everything has been working great. Was thinking of doing a CAM, headers, CAI and getting a custom tune. Until last week when things went horribly wrong.
To make a long story short, car had CEL on, Service Stabilitrac, very low oil pressure at idle (10 psi). My ultimate findings are in the photo below, scope inside of cylinder #8. When I manually turned the crank, the piston just sat there on the bottom. Obviously a broken connecting rod, which tore a gapping hole in the side of the block and piston. Engine is toast!
So I need a new engine, which is where I need some advice. The goal would be to reuse my Whipple of course. Also I would like to use my stock wiring and ECM, etc.
I was looking at Summit Racing and they have a couple options. First, what looks like a direct replacement https://www.summitracing.com/parts/nal-19434644
They also have what looks to be that same replacement but upgraded to 525HP https://www.summitracing.com/parts/nal-19434648
The upgraded 525HP seems to give me the CAM upgrade I was after and added power. Would everything else work with it? I'm guessing my ECM and wiring could be used but would need reprograming/tuning accordingly, yes?
I would truly appreciate any thoughts or suggestions. I live in CT so I was thinking about contacting Jannetty Racing to get their thoughts and if they could help with final programing/tuning.
Thanks for you time!
H8Rain is offline   Reply With Quote
Old 08-07-2023, 01:11 PM   #2
H8Rain
H8Rain's Avatar
well apparently I don't know how to add pics. one more try.....
[IMG]2023-08-07_12-26-56 by Mark Krumenacker, on Flickr[/IMG]
Old 08-07-2023, 01:24 PM   #3
gtstorey
At you mileage, I would probably inspect your heads and if not damaged, spend a little more and get a forged bottom end motor and freshen up you existing heads. Something like this.
https://www.thompsonmotorsports.net/...rgd-pis-stge-2.
With a basically stock crate you still have the weaker piston/rods and probably a smaller ring gap.
Old 08-07-2023, 10:27 PM   #4
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I was looking along these lines when I rebuilt mine but decided to forge mine as a l99 vvt engine. But If your heads are good which I kind of doubt it with all that carnage you could go with one of these just pick your compression ratio basically.
https://www.jegs.com/webapp/wcs/stor...0002&langId=-1
Good luck sir.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-08-2023, 08:24 AM   #5
H8Rain
H8Rain's Avatar
Hmmm…. Those prices aren’t bad. So I would need to get heads and a cam to go with one of these.
This is certainly going to be a learning experience!
Old 08-08-2023, 08:44 AM   #6
morepowerjoe
Yes sir unless your heads are still good.
Old 08-08-2023, 08:45 AM   #7
jeff657756
Drives: 2014 SS 1LE
With the fact that you will be boosted, i wouldnt mess with any of the gm crate motors. Check out Texas Speed, Thompson Motorsports, AMS racing, etc and get a forged short block. Have your heads checked and if they are still good, then use them.
jeff657756 is offline   Reply With Quote
Old 08-08-2023, 09:41 AM   #8
RupertPupkin
Drives: 2014 Camaro SS 1Le
I was originally going to go with Thompson when my engine blew, but by the time I pulled the trigger the price increased 10-15%. I was able to get a forged long block for 8800. Not bad imo.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 08-08-2023, 10:27 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
$7K and you trade up to a dart iron 427:
https://cnc-motorsports.com/cnc-comp...ymetrical.html
Your Whipple will be happy sitting on top of it...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 08-08-2023, 10:30 AM   #10
gtstorey
Depends on what you are doing with the car and whether you want the additional weight of the iron block.
Old 08-08-2023, 10:33 AM   #11
morepowerjoe
That's what I was thinking about. And doesn't the 427 usr different heads than the ls3?
Old 08-08-2023, 10:58 AM   #12
RupertPupkin
You can use ls3 heads.
730whp: 630Trq
Old 08-08-2023, 11:07 AM   #13
jeff657756
Drives: 2014 SS 1LE
Whatever you decide to do, save some money for your fuel system, clutch, drivetrain, etc.
Old 08-08-2023, 12:36 PM   #14
H8Rain
H8Rain's Avatar
This is all VERY helpful. I looked at Thompson and they are really expensive. I think if I were tracking or racing the car that would be a great option, but I'm just fair weather driving and jumping on it occasionally to beat the guy next to me.
So I think an aluminum black with forged piston and rods should be a good upgrade. I need to figure out the whole compression thing to see which I want to go with. Also need to figure out a cam that will be street drivable but provide that nice blub-blub-blub at idle.
When you say check my heads, do you mean for them being warped? I have never overheated so I'm thinking they should be good. Maybe use the heads but upgrade the valves, springs, pushrods, etc?
Do you think I should run a high-pressure oil pump?
I will be replacing the entire clutch as it was just starting to slip.
Thanks so much for information! I greatly appriciate it!
