Old 08-09-2023, 05:16 PM   #1
Ck1984
Drives: 2015 camaro LFX V6
max G-FORCE?
whats max Gs your car can pull according to HUD g force indicator
list model, wether you have stock suspension and tires or upgrades to either
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 08-09-2023, 06:34 PM   #2
Eddymel1998
Eddymel1998's Avatar
Drives: 2010 Camaro 2SS L99
I got a 2010 SS with stock suspension and pirelli pzero plus all seasons on it, most I did so far was .7Gs, think the car can do more then that but don't really have a spot to test reliably, I always flip to the lateral G mode when entering extra curvy roads though.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
Eddymel1998 is offline   Reply With Quote
Old 08-15-2023, 01:42 PM   #3
CyberPredator
50 Shades of Prey
Drives: TT/SS
Are you saying there is a factory gmeter? If so where?
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 08-15-2023, 01:53 PM   #4
Eddymel1998
Not on stock, I retrofitted a color hud in my car from a late 5th gen (2014 I think).
Also as side note I was going through some curvy roads this weekend and remembered this thread, hit about 0.8Gs at around 40mph, which was on a "banked" (sagging) turn so not sure how that messed with the reading, but I think thats about the most the car wants to give with my setup.
Old 08-15-2023, 01:58 PM   #5
Ck1984
yeah i dont have many places to test either just this one on ramp on my daily drive and i hit .78 on there but its banked a little too. on the less banked portion my tires start howling over .7
MY 2LT has a gmeter in the HUD display options, not sure about other models
maybe lesser models have it in the center dash display?
2015 2LT LFX 3.6L
Old 08-15-2023, 02:05 PM   #6
SlowLS1
SlowLS1's Avatar
How involved is this retrofit? I have thought about doing this myself...
SlowLS1 is online now   Reply With Quote
Old 08-15-2023, 02:28 PM   #7
Eddymel1998
I would say it's not hard but it is just a lot of work, there are few good guides on there as well as service manual diagrams but I would say those give about a 95% picture, you still have to figure out the last 5% on your own. The funniest part for me was that the actual mounting for the unit was already there in the dash, you just have to insert some clips and use few screws and it just slots in (minus cutting the hole).
Old 09-03-2023, 12:02 PM   #8
Ck1984
i managed .86 a couple times with outside tires startingto howl.
2015 2LT LFX 3.6L
Old 09-07-2023, 05:51 PM   #9
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
I've done 1.01 on the street. Stock suspension, Nitto Invo Tires, 275 in the front, 315 in the rear.
14Black1LESS is offline   Reply With Quote
Old 09-07-2023, 06:17 PM   #10
Ck1984
does a 1LE also come lowered, with wider track width, thicker roll bars, stiffer springs etc than lesser models like my 2LT as well as those bigger tires mentioned?
2015 2LT LFX 3.6L
Old 09-08-2023, 10:01 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
My buddies 2014 1LE stock is NOT lowered from the factory. If you want it lowered, you have to do it with either coilovers or springs. He showed me the build sheet for it and the suspension does have some Z28 items installed in it from the factory. So, yea, it will be stiffer and tighter on the road and track. And yes, the front wheels are 20x10 and the rears are 20x11.. Where the stock SS wheels front are 20x8, rears 20x9.. As well as the V6 Camaro's with the RS package on it.
Old 09-08-2023, 10:14 AM   #12
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
I don't believe 1LE's came with parts from the Z/28(I could be wrong) but a bunch of goodies from the ZL1:
Changes to optimize the 1LE for track-day use include:
  • Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for awesome body control
  • Higher-capacity rear-axle half shafts to help with increased horsepower levels of traction
  • Strut tower brace for improved steering and response
  • ZL1-inspired 20 x 10-inch front and 20 x 10-inch aluminum wheels
  • 285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear ( same as the front tires for ZL1 )
  • ZL1 wheel bearings, toe links and rear shock mounts for track performance
  • ZL1 high-capacity fuel pump and additional fuel pickups for fuel delivery during high-load cornering.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 09-08-2023, 10:18 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I forgot what parts they were, but he was excited when he showed me the sheet and pointed them out. They had the Z28 listed beside them in ( )..
Old 09-08-2023, 10:30 AM   #14
NoDakZ/28
NoDakZ/28's Avatar
Right on, I would like to see that list! They do share the 3.91's. My 1LE was a great car and super fun on the street but my Z is on another level, sure fun to drive!
2014 1LE - Sold
