Old 08-14-2023, 05:22 PM   #1
Hustonm3
Hustonm3's Avatar
Drives: 2010 Whipple'd SS
Rotor Screw- Screwed
Well, I've gone and done it... Changing out my calipers and rotors on my SS to the larger Z06 brake upgrade. I stripped the Torx screw (T-30 ) on one rotor. Looking for advice on getting it out, maybe an easy out, but what size? Also, looking for a replacement Torx bolt/ screw.
Any assistance and/or advice would be appreciated.
Hustonm3 is offline   Reply With Quote
Old 08-14-2023, 06:52 PM   #2
SlowLS1
SlowLS1's Avatar
Drill out the head and once the rotor is off, use pliers to remove what is left.
Replacement part number is 11570339 ( Rotor will function fine without this screw, it was for assembly process at the factory. )
SlowLS1 is offline   Reply With Quote
Old 08-14-2023, 11:26 PM   #3
Hustonm3
Hustonm3's Avatar
Thanks Slow, will give it a shot .. still would like to replace the rotor screw anyway. Thanks again!
Old 08-15-2023, 01:32 AM   #4
Parts Peddler
Drives: 2014 1LT/RS
^^What he said. Screw serves little purpose.
Parts Peddler is offline   Reply With Quote
Old 08-15-2023, 05:06 AM   #5
HDRDTD
If you are a skilled welder, you could consider welding another torx bit onto the head of the screw, then backing it out.
