![]() Drives: Chevy Camaro Join Date: Aug 2023
Hello,
I’ve got a 2010 Chevy Camaro LT V6 and I’m wanting to do some upgrades. Where should I get a 160 degree thermostat? Is the Radiator Cap what’s rated for 160 degrees or do I need to install the whole thermostat? It needs new shocks. What kind should I do if it’s my daily driver and where should I get them? What’s a good Air Intake Filter to get? Are there any recommended upgrades I should get? |
I have a 2010 camaro 1lt with the v6. I added the airair inatek setup that used the factory box as i did not want a hot air intake. For shocks kyb makes decent set of struts for daily driver use. i did a rev 9 exhaust on mine and it sounds great...hope this helped some. id be sure if your close to 100k check spark plugs and get a decent catch can...
David Vianu
2010 Synergy Green 1LT |
First off since it is a 2010, and depending on how many miles are on it, I would change out the spark plugs for sure. Next you should get a good catch can because these engines are bad about oil in the intake. I run an RX can and it does a great job, there are many out there to choose from. As for a CAI, that depends on how much money you want to spend, but they are not necessary, as a good K&N drop in filter will do the same, more air flow. As for the shocks and struts, I am still running stock AC Delco OEM's, nothing wrong with them. Only replace them front and back once to date, and I have 129k miles on her. Oh, and on the thermostat, if you want a 160 one, you can get one from Summit Racing. Got mine there. The radiator cap is pressure sealed.
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
I like that air filter in my sig.
A 160 absolutely sucks in the winter time and i would just go with a stock unit. I would replace the anti freeze tho and fair warning, these radiators love to trap air. Pay attention to the rad cap since they come apart as the get older and the seal loves to go flat and leak.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
![]() Drives: 2010 Chevy Camaro 2LT RS Join Date: Aug 2023
2010 Chevy Camaro loss of power
Hey guys,
I was wondering if you guys could help me out. the other day the car turned on and had a loss of power for all gears and wouldn’t go over 60mph nor over 2000 rpm. Then I let it sit for a couple hours and let it sit then a strong gas smell came through all the AC vents and when I turned it on it started driving fine again but I noticed it doesn’t sound the same and when it comes on sometimes it turns on weaker than normal. I have a 2010 |
| Tags |
| 2010, partshelp, upgrades |
