08-17-2023, 05:35 PM | #1 |
Drives: 2011 Camaro ls Join Date: Aug 2023
wont crank
i just got a 2011 camaro LS in a trade . It does not run, the starter does not attempt to crank and whenever I open the trunk ,door, or put the key in the ignition there is a clicking noise that I traced back to the large connection on the driver side of the mass flow sensor. sitting in the seat I held down the clutch and brake and turned the key the starter did not spin, nothing happened
i made sure the battery is fully charged and the cables are clean and firmly secured to the battery, the dash board lights up everything seems normal. the check engine light flashes while I turn the key but nothing happens. I checked some fuses under the hood, they all looked good. what is causing this none crank issue ? i have to get it to crank |
08-18-2023, 05:03 PM | #2 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
There might be a shunt in the trunk.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
08-18-2023, 06:56 PM | #3 |
Are you sure? He did say there was some clicking on the driver side around the MAF area. Maybe a squirrel, or a rat chewed some wires??
08-18-2023, 07:17 PM | #4 |
Drives: ABM #93 Join Date: Oct 2018
Yep this is classic shunt behavior. I bet shunt is up under the package tray area, another common place is behind the headlights.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
08-18-2023, 07:51 PM | #5 |
I said maf but I could be wrong,maybe throttle body it's on the front of the motor.the engine is a 3.6 .the clicking is coming from the plastic housing on the driver side of the unit.
08-18-2023, 07:54 PM | #6 |
Also I assume your referring a shunt as a "short"
08-18-2023, 08:01 PM | #7 |
Shunts can be short. Maybe someone else can chime in. I'm not really that good on the electrical stuff but these cars can do weird things. Any stabilitrac lights?
