Old 08-18-2023, 08:05 PM   #1
therigwelder
therigwelder's Avatar
Drives: 2011 Camaro ls
no crank no start
ok i will try breaking down my issues.my last post fell flat. either this site is washed up or nobody has a clue what i am talking about. the car is a 2011 camaro LS. i have a no crank no start issue, the battery is fully charged and good connections. there is 12.5 volts at the positive post under the hood. when the key is turned on everything lights up as it should however the CEL flickers faintly and continuous. could i hook up a remote starter switch and bypass the ignition and see if i can get it to fire up?
therigwelder is offline   Reply With Quote
Old 08-18-2023, 09:11 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
The CEL flickering… have you tried to pull any codes?
0stones0 is offline   Reply With Quote
Old 08-18-2023, 09:32 PM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
There are really good people here. I'm just guessing & don't have a clue. Someone will help.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 08-18-2023, 09:45 PM   #4
therigwelder
Hooked up the obdII and there were no codes but the battery was pulled when it got in my yard because it only registered 8v on the battery put a fresh charge on it and the battery tested good,so the battery is not an issue in this equation.wish I woukd have tried pulling codes before I yanked the battery
Old 08-18-2023, 10:19 PM   #5
acutron42
acutron42's Avatar
Hey, we are just messing with you. Welcome to the forum & take the starter out & have it checked @ any parts store.
Old 08-19-2023, 06:25 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
As Acutron said, we were just joshing with ya!! Like he said, pull the starter and have it checked, or maybe the cable that goes to the starter is lose, or just bad at the connection. If you have 12.5 at the under hood terminal, it could be a toasted starter. Good luck..
Old 08-19-2023, 10:11 PM   #7
therigwelder
okay, i have done a lot of research and investigating today. i have found the clicking noises i am hearing are coming from the tps. this happens whenever a door, trunk, hood is opened or closed and KO. apparently it is a common problem with camaros. i don't think the problem is the TPS because i still have the no click no crank condition. I pulled the starter and it tested good, the battery is fully charged with new terminals, Every fuse under the hood, in the trunk and inside the car are good. I pulled the starter relay and tried to jump out #30 and #87 ports.#30 had power but when i jumped into #87 i got a small spark and nothing else(i think there is resistance there) the starter should have engaged. I have a starting charging schematic only so I don't know how the BCM interacts with the ECM on the IGN side. I am also trying to figure why the alternator has a wire going to the starter solenoid as well as how the TPS ties into all this mess, the only conclusion seems to point to the ecm. the previous owner told me that he got stuck and it started making a tapping sound and the car shut off and never restarted.I am thinking as the PO was getting unstuck he revved the car up to high rpms and the tapping he heard was the tps.is there a rev limiter on these cars?
Old 08-20-2023, 09:23 AM   #8
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
For what it is worth, I had a no start/no crank condition on my Camaro years ago. It was the Throttle Body, and most likely the harness connection to it, or some other harness connection, because I went through all of them that I could access.
Battery was good, and like you everything else was good. I however did have some codes, and maybe you also had some, but cleared when disconnecting the battery.
So I cleaned the TB Harness connector, and checked all harness connections. I was able to start car after mashing the throttle a few times before attempting to start the car and got a CEL and Codes P2135 TPS Voltage Correlation, and P2176 Throttle Actuator Control System Idle Position not Learned (Limp Mode). Cleared those codes with my SCT X4 Flash tool and then got CEL and P0122 and P0223 TPS Low Voltage Input/High Output. I found the SCT X4 won't read codes as well as a HP Tuner MPVI3, and some codes are permanent and can only be cleared by fixing the issue and driving the car. With the HP tuner interface you can look at a whole host of parameters before even starting the car. Like TPS and accelerator pedal position, voltage, etc.
So check all wire harness connections and look for potentially bad grounds. And low battery voltage can cause maddening issues on these cars.
Or - VATs also will cause a no start. https://www.camaro5.com/forums/showthread.php?t=548558
hesster is offline   Reply With Quote
Old 08-20-2023, 12:52 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is some good info on the rev limiters, and yes they have it set from the factory, unless it has been tuned differently.
https://www.camaro5.com/forums/showthread.php?t=305623
Old 08-23-2023, 10:55 AM   #10
therigwelder
I am still trying to figure out the no click crank situation out.so let me try another approach,there is a clicking noise whenever I open the hood door or trunk.the clicking feels like it is coming from the passenger side injector harnesses.the engine is not running,the key does not even have to be in the ignition.if I can figure out this odd situation maybe I can get it to lead me to the no click
Old 06-19-2025, 04:37 PM   #11
kapomen
Drives: 2011 Chevrolet Camaro LS
Question Follow up on issue. Experiencing the same
Sorry to necro the post, but did you finally resolve this issue? If so, how?
As of 36 hours ago, I've been experiencing this exact scenario with my 2011 Camaro.
I thought it was a weak battery (despite it being only 10 months old) due to frequent starts without driving long enough for the alternator to recharge the battery. I've had that happen before. A buddy came out to help jump it off, but realized that it was not starting or cranking.
No feedback on engaging the ignition other than dashboard lights attempting to light. But I hear this low clicking under the hood on the passenger side when I open or close doors or the trunk, and when locking and unlocking. It clicks 8-10 times in quick succession.
My working theory is that it's either the starter motor/solenoid or a fuse/relay (BCM, powertrain, or ECM), but it seems by your account here that it may not be any of that. There is not obvious signs of damage on the fuses and relays, but that clicking is certainly coming from around that fuse box. The starter is below/behind that area of the engine, so it's not ruled out yet.
It was all operating reasonably well, and then it just stopped cranking/starting. Short-term, It's left me stranded in a bad way.
kapomen is offline   Reply With Quote
