08-20-2023, 09:15 AM | #1 |
Drives: 2010 Chevy Camaro 2ss Join Date: Aug 2023
LSA Injector Swap on L99 w, bolt ons
Hello,
I have a 2010 Chevy Camaro SS L99 with mild bolt ons at the moment (CAI, exhaust.) I plan to do a cam, headers, ported heads, E85 all at once in the near future. I currently suspect I have a clogged/failing injector. Am I able to swap LSA injectors in with no tune in preparation for future mode without any issues? |
08-20-2023, 10:26 AM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Pretty sure that’s a use because Fuel Pump will only push what’s needed.
Orange Krush II
08-20-2023, 03:58 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
No, your ecu has current injector performance data tables. Changing injectors will require updating the data or the ECU will demand X amount of flow and get something else.
08-20-2023, 05:45 PM | #4 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
On top of needing to change the tune, the LSA injectors have a different spray angle that doesn’t play well with the ls3 intake.
https://forum.hptuners.com/showthrea...-Swap-into-LS3 |
