Old 08-23-2023, 10:06 PM   #1
CountingZs
CountingZs's Avatar
Drives: 2015 Z/28 | 2018 Z06 Carbon 65
Transmission, clutch or my imagination?
Went for a drive this past weekend and noticed something a bit odd.
When sitting at a stoplight, flat pavement, stick in neutral, normal idle, there is an ever so faint “thump” that can be felt in the floor board/pedal 1-2 seconds after I disengage the clutch (pedal to the floor). Repeatable every time you cycle the clutch (engage then disengage).
TR6060 shifts like a dream, clutch has a nice smooth take up, car hooks and books like a champ even in low gear pulls.
Has anyone experienced something similar? Or am I just too used to rear transaxles from vettes and the TR6060 input shaft naturally spins down quickly?
2015 Z/28 #607
2018 Z06 Carbon 65 #553
Phil 3:8-9
CountingZs is offline   Reply With Quote
Old 08-24-2023, 10:55 AM   #2
ABM2SS
Drives: 2010 SS M6 ABM
Yeah, the TR6060 in my SS started doing that, which evolved into a clicking noise. Never did figure-out what caused it. I had Hawks Motorsports rebuild my transmission because the Syncros were getting bad. No noises now and performs like it did when new. 288,000 miles on it when I sent it for the rebuild.
ABM2SS is offline   Reply With Quote
Old 08-24-2023, 12:15 PM   #3
1970judge
Drives: 2015 Z/28, 2007 HHR
Normal. Straight from the mouth of the pT engineer for the car.
1970judge is offline   Reply With Quote
Old 08-24-2023, 05:27 PM   #4
highrevving
highrevving's Avatar
Drives: Z/28
I hear so many sounds coming from the car. Plus, shift boot is kind of warm.
Bare-bones with no insulation track car.....
highrevving is offline   Reply With Quote
Old 08-24-2023, 10:32 PM   #5
CountingZs
CountingZs's Avatar
ABM2SS that is impressive! Sounds like I’ve got a good 280K to go before starting to worry…
1970judge reassuring to hear. Hats off to Al and the folks who engineered these, entire car feels solidly overbuilt.
highrevving all I hear from mine is a lopey LS7 at idle and deafening madness ripping through the gears. Forget the A/C, windows down and revs up!
2015 Z/28 #607
Phil 3:8-9
Old 09-02-2023, 08:45 AM   #6
FLOW TIE
FLOW TIE's Avatar
Drives: 2015 Z/28 #898
All the above from my car.
The thump in the trans, the thump from the floor pan, etc.
I’m right at 4,600 miles.
No sound deadening and stiff chassis, all kinds of noises.
Have fun, it’s a BEAST!!
FLOW TIE is offline   Reply With Quote
