Clutch reservoir
Anyone know what the source part/car is for the reservoir? I would like to make my own bracket for a different mounting position.
Now, whats the part number? I can find the whole assembly not just the reservoir with cap Last edited by Toybreaker; 08-24-2023 at 11:17 AM. |
Ive heard its from a newer GTO, but not sure if this helps
![]() ![]() Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
FasNuf is correct. Look at the GTO reservoir.
Whole assembly, nothing on just the reservoir.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Just the reservoir. G8 used them too.
You can get a bigger one from Wilwood. I got one from a track guy on here and put it on the vert. More expensive, but better overall solution.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#6 |
Are you looking for a eom replacement reservoir or a separate clutch reservoir?
#7 |
![]() Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6 Join Date: Dec 2016
#8 |
Another forum member made these brackets and they work perfect using the stock clutch hose
#9 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Reservoir alone is p/n 92065790
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
