Old 08-24-2023, 11:06 AM   #1
Chester
Drives: 2015 Camaro SS
Range AFM Power switch
Anyone with a Range Afm disabler using one of these power cords for shutting power off not having to unplug range AFM? I'll try to attach link
Chester is offline   Reply With Quote
Old 08-24-2023, 12:07 PM   #2
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I had to dump the Range. It triggered the loss of the electric power steering while driving. That was big time dangerous. Ever try to steer these Camaros with no power steering?
Moto-Mojo is offline   Reply With Quote
Old 08-24-2023, 12:58 PM   #3
Chester
Never heard of that kind of problem when I researched them just the battery drain. Had one on my 2010 didn't have any problems. Have to see if anyone else response with troubles. Thanks for response.
Old 08-24-2023, 05:34 PM   #4
JamesMyBoy
Drives: 2014 2SS/RS
FWIW
I've been using my Range Device since December of 2014 with no issues (other than forgetting to unplug it for a week once). I have not sent it in for an update, and only have about 35K miles on my car. Perhaps I've been lucky, but I also have not heard of this problem either. Keeping my fingers crossed!
JamesMyBoy is offline   Reply With Quote
Old 08-24-2023, 05:38 PM   #5
Moto-Mojo
Moto-Mojo's Avatar
Oh, it provided me with new and wonderful code fault's all the time. In all fairness, I bought it used, here, and it did not have all the updates for my model year. Allegedly. I could have sent it in for those but didn't. I just got tuned instead.
I can save you some 'potential' issues too by simply recommending a good tune. Good luck out there.
Old 08-24-2023, 05:44 PM   #6
Moto-Mojo
Moto-Mojo's Avatar
One last comment...I was still under warranty when I got the tune. The Range became so problematic - and I wanted to kill that AFM so bad, I took the chance. But as James says above, many have not had the problems I experienced.
Old 08-24-2023, 07:03 PM   #7
Chester
Been doing more searching/ reviews , like you said some no problem some do. Thinking as long as I have a good extended warranty and very little town driving going to run it without AFM disabler and use paddle shifter for now.
Old 08-24-2023, 08:17 PM   #8
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
I use a Range device on my avalanche and never unplug it, and it doesn't drain the battery! Don't know it it's different on the camaro!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
Old 08-24-2023, 08:31 PM   #9
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
I had the Range...until it started throwing codes. Sold it for $50 just to get it gone.
"Never cough into a full ashtray."
Danial is offline   Reply With Quote
Old 08-27-2023, 01:10 PM   #10
whitehorse
whitehorse's Avatar
Drives: 2010 IBM Camaro 2SS
I use one of those switches on my because the Range would also drain my battery if it didn't get driven every week. Turn the switch off when it sits in the garage and on when I go to drive. I have had it for several years and have never had a problem.
whitehorse is offline   Reply With Quote
Old 08-27-2023, 02:37 PM   #11
Chester
Thanks for the reply's. See its hit and miss. I'm running in manual and paddle shifters to stay out of AFM. pretty simple, gets to be no brainier more I drive
Old 08-27-2023, 03:01 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, after a while you do it enough it becomes second nature.. Have fun!!
Old 08-28-2023, 12:58 PM   #13
Blue 13
3P171 USAF Combat Arms
Blue 13's Avatar
Drives: 2013 SS/RS
Get it tuned out if you can. Better is replacing all the AFM garbage as it will break, and it’s not cheap. Absolute rubbish it’s on the motor to begin with.
416ci LS3/Vortech V7/Built 6L80
996.6 RWHP 794.9 RWTQ
Blue 13 is offline   Reply With Quote
Old 08-28-2023, 02:35 PM   #14
Chester
Think that will void my extended warranty good for another 45K miles or 60 months.
