08-27-2023, 04:57 PM | #1 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Hard pop or noise in front left under hard braking / conerning
Hey guys, got a question for ya.
2010 SS, stock front end components with camber plates and airlift suspension. PS4S on all corners. First and only time I had this happen and hoping someone has an idea. Very tight right hand turn, downhill and hard on the brakes, car was for sure leaning heavily on the front left! Might be the hardest it's been pushed so far. The PS4S were warmed up and taking everything I threw at them. At the peak of the curve, and pronounced pop or bang was heard / felt from the front left. I fully expected the tire got into the fender. Nursed it for a mile to a pull off to do a quick inspection and found nothing wrong. No marks on the tire, inside or out. Camber plates had not moved, all suspension parts appeared normal, nothing funny with ABS or the air lift system. Beat on it some more and never replicated the noise, seemed normal. I'm at a loss and looking for advice! Thanks, Brian
08-27-2023, 09:05 PM | #2 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I had a loud pop sound when I was pulling into my Driveway which is not any kinda crazy angle yesterday and it was from the front left, I have no idea either, I am assuming it was a sway bar link but I have no idea either, Nothing seems to be broke or loose.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
08-28-2023, 06:51 AM | #3 | |
While your comment is valid, the spam link you dropped in the quote is highly sus...
08-28-2023, 12:21 PM | #4 |
Drives: 2013 1SS Join Date: Dec 2012
It could also be the struts wiggling around in the towers. They aren't rigidly mounted.
08-28-2023, 06:36 PM | #5 | |
I guess I need to find a large open parking lot, and mount a GoPro on the fender and see if I can replicate it.
