Old 08-31-2023, 10:48 PM   #1
antho1jp
Drives: Chevy Camaro
2011 with after market Halos Issue
I just bought a 2011 Camaro LT and didn't realize that the headlights don't work. The car has Halos with a model on them KHC K130551 google links to https://www.amazon.com/Smoked-Camaro.../dp/B079CCPCGX
Whoever did this did a poor job the wires are in disarray and I'm trying to fix it. But I noticed everything I look up for factory Headlight Harness the socket only has 3 wires and mine has 4. This is not an RS model, it is the LT so I can't imagine there was an option for factory Halos back then but I don't know.
My question is, do you think a 10-13 Camaro Non-RS to RS Headlight Harness would help:
https://www.gen5diy.com/products/10-...=7605277065274
Or does anyone know where I can find the Headlight wiring diagram?
I like the look of the Halos, but before I started digging in the Halos lights were the only thing turning on but the actual headlight bulbs were not. The DRLs are working fine, blinkers good as well. It's just the Head lamps that won't turn on. I tried hooking the headlight bulbs directly bypassing all the crazy wiring going on and they turned on briefly but then turned off. I'm thinking there is too much power drawing from the same source.
Honestly for now I can do without the Halos and just would like my headlights to work, but the connector is a 4 wire and everything I see shows a 3 wire OEM bulb connector.
How can I use the 4 wire connector to plug in some headlights?
TL;DR: Headlights don't work
1) do you think a 10-13 Camaro Non-RS to RS Headlight Harness would help
2) Or does anyone know where I can find the Headlight wiring diagram?
3) How can I use the 4 wire connector to plug in some headlights?
antho1jp is offline   Reply With Quote
Old 09-01-2023, 09:32 AM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Halogen and HID.
Old 10-29-2023, 05:03 PM   #3
antho1jp
Thank you!
Originally Posted by chevy pilot View Post
Halogen and HID.
Thank you! This is exactly what I needed.
Old 10-30-2023, 02:29 AM   #4
chevy pilot
gen5, halo lights, headlamps, wiring harness
