Old 09-01-2023, 01:50 PM   #1
Don Keedic
Drives: 2010 Camaro 2SS/RS
Best Clutch for single turbo LS3 setup
Trying to get a parts list together and wrap my head around the pricing. Gonna go with a single VSR 7875 turbo. I was looking into McLeod, and as with everything there are negatives out there. But, it seems I have found more positives than negatives with Monster Clutch. What are your guys recommendations/experiences. Should I be looking into something else for this setup? Thanks.
Don Keedic is offline   Reply With Quote
Old 09-01-2023, 02:18 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
You're on the right path, most likely a twin-disc depending on how much RWHP you're targeting.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 09-02-2023, 06:50 AM   #3
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
clutch
Mcleod, ACT, Monster, and so on, if installed correctly and shimed as needed. You wont have any problems, most issue people have and post are due to improper install,
Look up does your clutch setup need a shim, I believe Tick performance has a great writ up on it.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 09-02-2023, 11:19 AM   #4
dreksnot
dreksnot's Avatar
While you're in there and regardless of your clutch choice, make sure you go with a billet release bearing support.
Old 09-02-2023, 02:00 PM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
And put a remote bleeder line in.
Old 09-05-2023, 09:45 AM   #6
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Cheaper option (single disc) would be a Spec Stage 3 or Stage 3+ depending on the power level goals. It held fine 3 years 30K, 20K over 9XX WHP on 20PSI Stock Motor.
Better option will give you headroom to grow Monster Twin Disc. Will support more power. Will give you a stock pedal feel making drivability relatively easy depending on the set up.
With that said either way you do it, get a new OEM GM Slave, Monster Billet Support Bearing, and Monster Remote Bleeder.
For Reference I personally now have a Monster Triple Carbon in the car, but we are big power levels in comparison. I went straight to the triple instead of twin disc.
johnnyb305mia is offline   Reply With Quote
Old 09-05-2023, 11:07 AM   #7
dreksnot
dreksnot's Avatar
It's pretty amazing that I'm still on my 2013 stock OEM GM Slave cylinder and I can't count how many clutches I've burned through... lucky me, I reckon!
Old 09-10-2023, 07:20 PM   #8
JarVan55
Drives: 2010 Chevy Camaro SS
I have a single turbo setup, also using the vsr 78/75 2.5g, making around 14lbs right now and my mcleod rxt1200 seems very comfortable, smoked a regular rxt with it. +1 on upgrading to a billet support, and speed bleeder while there.
JarVan55 is offline   Reply With Quote
Old 09-12-2023, 12:29 PM   #9
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
The Mcleod RXT1200 Is a great option for your combination.
Sales@Phastek is offline   Reply With Quote
