09-03-2023, 01:00 PM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Next batch of parts
Just ordered some of what i would call the finishing parts as far as power wise goes. Finally going to be finishing up the secondary port injection system. I also finally got myself a proper catch can.
Going with full fragola -8 a fittings and fuel line for everything, and also bit the bullet and went ahead and purchased the griptec 3.5 pulley for the procharger. Right now i’m making about 11-13 psi on the 3.85 After all this is installed we will be hooking up the Reflex+ module and we will start figuring out the fueling for the secondary port injection. Also i might add, i didn’t go with the port plates. I have a holley low ram with fuel rails, so i just purchased the control module and the injectors. Once all of this is done i will be back on full e85. and not sure how much boost i will make but i would like to shoot for at least 18 psi. Not sure how much power all of this will equate to, but the current butt dyno says about 800 give or take on pump 91 and 11-13 Psi
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
09-03-2023, 11:52 PM | #2 |
Drives: Whiney Dodge Charger Join Date: Jul 2023
Whats better?
Ordering, waiting, or unboxing..
Janitor at RRP Racing
RRP garage: 2023 1SS 1LE A10 2023 1SS 1LE M6 2023 2SS 1LE A10 2023 ZL1 A10 See you at Willow Springs |
09-04-2023, 03:46 AM | #3 |
unboxing 100000%
ordering is a quick high, unboxing is a high that lasts until you’ve got it installed
Tags |
boost, build, fuel, procharger, tuning |
