![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
First time out with this car. First time to a drag strip in 8 years and I have to say, cars are so much faster these days. Anyway….
Stats… 2022 Camaro LT1 A10 100% stock and full weight + drag pack. VMS 17x10 rears with 305 45 17 MT ET ST R and 18x5 fronts with 28x4.5 Hoosiers. Exactly 1/2 tank of 93 octane. Drove 2.5hrs to track with 26PSI in the MT and kept them there for all 4 passes ![]() Seemed to hook fine. Maybe could have improved 60’ a bit with lower PSI. It was a street night so track not prepped like a test and tune day and it was HOT! Density Altitude = 2850 60’ 1.850 1/8 7.904@91.24mph 1/4 12.160@115.84mph Considering the high DA and weight of the car I thought it did well for a stock car. This car will have no issues at all getting into the high 11s in October at this track with no other changes needed. I’ve ran in -2000 DA up here in the past. ![]()
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB Last edited by Dynamical; 09-09-2023 at 12:04 PM. |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Sounds pretty good. Mine only ran 12.6 stock.
Might want to ask around about a trans tune. It might be limiting your ability to get better than a 1.8 60 ft, but not sure about your year/trans. But stock trans tune might be causing engine torque mgmt on launch. Did you grab any logs with HPT?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
#3 | |
The tune will come in time after I figure out which way to go with this car NA or FI. Either of the two I don't want extreme, I want a nice midrange setup like my old 4th gen mostly street car. I do know what you mean about the 1.8 60' though. I tried stalling RPM around 1200 or so and that's what gave me the best time despite others saying I need to stab it off idle. When I stabbed it off idle, the car did a weird bogging down kinda thing ![]() No logs, I'm ignorant to ECM/computer tuning. I'm just a wrench turner right now but it's looking like I need to learn more about tuning if I'm going to mod this car vs the 4th gen. I am located in CT so Jannetty is about 1 hr away.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
#4 | |
![]() Drives: Chevy Camaro Join Date: Sep 2022
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
#5 | |
The bogging is most likely the torque mgmt I was talking about. Engine is closing throttle and/or limiting timing... that's the trans tune issue I was talking about. You'll have a hard time getting better 60' because the ECU is literally trying to prevent that (via the transmission tune settings) ![]()
#6 | ||
First trip with the 2001 was in 2200+DA. Car just had boltons at the time...Full exhaust, lid, ssra and smaller stuff but it was on street tires. It did hook though. It ran these numbers... 60'...2.092 1/8...8.580 mph...85.32 1/4...13.197 mph...106.93 Right off the bat, this stock 2022 is a full second quicker. I'm pretty excited. My next step is to go back in Oct for some crazy low DA and get the best possible time so I can compare it with the best time I got with the 2001 from above in Oct DA. That 2001 in -1245 DA did... 60 1.958 1/8 8.165 mph 88.14 1/4 12.638 mph 110.04 I did add Mickey Thompson Drs for that run though. As you can see I have all my old data but it doesn't end there either ![]() So next year I'll add the boltons+tune, run it down the 1/4 and compare with the next set of data from the 2001 which had a ss3600 stall and weight reduction ![]() Quote:
![]() So now I know I'm not the only one experiencing this bogging/cutting power and there's nothing wrong with my car. Good to know! When you got a tune how much did it help your 60'? I can't wait to get this thing tuned!
#7 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
#8 | |
![]() I guess if the LT1s don't have launch control it won't matter anyway but after a good tune I wouldn't care about launch control anyway?
#9 | |
But on the A8s it was said a trans tune could be worth .2-.4 et in the 1/4 mi at least with forced induction. It sounds like its not as helpful on the A10s, but still worth a tenth or two? When stock, i could feel the torque mgmt kicking in even during the burnout.
#10 | ||
Press traction control button twice (in sport mode). Press the brake pedal really hard with left foot. Press the gas pedal WOT 100%. Engine revs to 2k approx and the engine chops some cilynders, release the brake pedal and you're flying. |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
My 2017 SS A8 with just a 17" MT on back, plus a (worthless) drop-in air filter inside the unmodified stock airbox, went 11.9@113 in the autumn (1.76 60'). Before this I had run some 12.0s at 114 (1.83~1.85 60') with the bone stock car on the stock runflats in the weeks preceding this run. So for me, I only gained around a tenth from the DR and the (now I know worthless) air filter on the otherwise-stock car.
No question the stock TCM hampers performance of an SS/LT1. For my 2017 T87a, once tuning became an option from HPT, cost was 200 to unlock plus 200 for the credits. That's worth it IMO if you're tuning the ecm anyway and therefore already giving up the warranty. Not sure what the HPT price is on a T93 like you have, but honestly the trans tune helped my car a lot, and I'm talking bolt-on level as well as power adder. Example, with just 17" rear DRs (no skinnies), flex fuel ecm and tcm tuning, the aforementioned worthless air filter, a useless v-max ptb, and a driveshaft loop (extra safety but did add ~6lbs) I ran 11.3@119 with a 1.64 short time. |
#12 |
Guessing that you've never raced on a drag radial? The launch control IMO is calibrated for the stock tires. Once you've installed drag radials, it should hook up without computer intervention. For me, even on the stock SS runflats, I was already turning T/C off for drag racing and not using launch control. Had read that the nannies were slower than driving it yourself, and went with that advice at the time.
#13 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Launch control is for the street and not the track. You'll run slower trying to run launch control.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
#14 | |||||
![]() Quote:
![]() Quote:
Well shit, those are pretty good times ![]() Quote:
