![]() Drives: Camaro RS Join Date: Jun 2023
Major Problem.. What Now??
Soo, I’ve found a major problem.
There’s a crack in the block where the idle sprocket goes. Primary chain was completely broken. I have the other half. I’ve tried JB Weld, doesn’t work. I’ve tried a bigger screw. Not working. I’m clueless.. thinking about selling at this point. Any tips or advice? 2010 Camaro RS 3.6L |
#2 | |
![]() ![]() ![]() Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Time to source a junkyard motor for the cheaper fix. Crate motor if opposed to junkyard parts.
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
That's a head, not the block. (Refer to the other thread he started)
You should take it to a shop and have the head replaced. I'd seriously look into value/reward. That's an expensive fix- probably around $5000. Hopefully you didn't buy it like that. |
#4 | |
#5 | |
The crack is in the block.. (refer to arrow in picture below) .. it’s where the sprocket goes. Can’t install sprocket due to this crack.. I’m thinking bout selling the car. It’s a V6, great body, comes with all the features. I just don’t think replacing the motor is worth it financially right now.. I hate that this has happened. |
#6 |
Well crap man, that just sucks!! Sorry about that one.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
Damn that blows. Best of luck with it. That would be a huge kick in the shorts to me. Kinda sucks that it’s pretty easy to LS swap everything except for the cars that had LS engines as an option…
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
#8 |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
You may be able to have someone TIG weld it and re tap.
#9 |
2&THEHIT
So you have a cracked block and head?
https://www.camaro5.com/forums/showthread.php?t=619395 Definitely time for soul searching. |
#10 | |
