![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
ZL1 front rotors
Besides the 2 piece front rotors, where and what other options do you guys use?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
I bought DBA rotors and pads from KNS Brakes. Been running them since I went to the six piston calipers.
