Old 09-23-2023, 12:26 PM   #1
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
Brake pads look off
So I upgraded my rotors and brake lines along with dot 5 fluid for track days. Taking off my driver's front caliper I noticed some flaking that came off and looked like material from the pads. So out of caution I got new pads for the whole front. Thank God, look at these pads. WTH, they are power stop extreme pads. Anyone else seen this?
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 09-23-2023, 01:12 PM   #2
redcoats1976
had some cheapie drum brake pads on my old tempest look like that after one 100-0 stop.after that i used raybestos gold.im thinking you did a few hard stops there...
Old 09-23-2023, 03:49 PM   #3
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
Yeah my Powerstop brakes didnt last at all. Powerstop wouldnt honor the warranty so i said F.O. and went to R1!!So far so good.
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 09-23-2023, 04:40 PM   #4
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
I am starting to do track days and I had those brakes on when I did my last event and had brake fading(I think). Of course the fluid in the brake system was 8 years old. So it was over due on upgrades.
Old 09-23-2023, 07:34 PM   #5
FASTFATBOY
Drives: 2013 ZL1
Buy some real pads like Raybestos ST43 and throw that junk in the garbage
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 09-23-2023, 08:58 PM   #6
bsn
Drives: 2013 ZL1
I hope you meant DOT5.1 instead of DOT5, you definitely don't want to run DOT5 for any performance use.
bsn is offline   Reply With Quote
Old 09-24-2023, 03:19 PM   #7
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
I did mean 5.1 for fluid and I will check on those pads that you recommended. For now I got Brembo NOA pads from AutoZone. I'll give them a try and see. Now I am curious what my rears look like since I also put power stop in those.
Old 09-25-2023, 11:55 AM   #8
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
As others have stated here, ditch the cheap PowerStops.
Tires and brakes are the two big things I do not cheap out on.
I'm running Hawk DTS70s in the front and DTS60 in the rear with zero issues on my local track. Raybestos ST43s are on the top of the list as well.
They were on "indefinite back order" when I tried to order some, so I went with Hawk.
Since you already did the brake fluid, get yourself some quality pads and maybe some titanium spacers up front as well. They help keep pad heat off the calipers.
If you get more into track days, look into a ZL1/CTS-V/Z06 front conversion.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 09-25-2023, 01:26 PM   #9
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
My R1 concept brakes have performed well for me since I installed them but they sure are noisy at low speeds. Also, I paid more for the black finish on the rotor hats and that lasted maybe a few months
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 09-25-2023, 09:09 PM   #10
Bluebagger06
I like the black look but i figured it wouldnt last so i passed on that, I just run there rotors and have hawk pads and only have a little squeak with cold after sitting for a few days. Other than that mine are very quiet and absolutely no brake dust!!
GPI Powered
Old 09-26-2023, 07:14 AM   #11
Arogg
Arogg's Avatar
I don't remember exactly what I ordered, I'm sure I can look it up but its a complete R1 package so rotors and pads. They aren't noisy all the time but occasionally and mostly at slow speeds like coming to a slow stop or maybe holding the brakes a bit rolling thru a parking lot. I dont feel too bad about it, the owner of my company has a $250k+ Aston Martin and those brakes scream as he pulls into our parking lot
Old 09-26-2023, 12:22 PM   #12
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
We have used the Hawk DTC70 and DTC60 with great success.
Sales@Phastek is offline   Reply With Quote
Old 10-09-2023, 10:17 PM   #13
NewCamaroSSowner
Drives: 2011 Camaro SS convertible
OK my 2011 Camaro 2SS finally needs brakes at 49,000 miles. I do not do track driving but I do drive fast on the street and like the good brakes I had with the factory, but dealer prices are insane, also the only thing special is the Brembo calipers. The rotors and pads are ac delco I was told by the dealer. So I am wanting to know the best rotors, I feel like I should replace them instead of trying to have the old ones turned? Also which pads are the best for street use at a reasonable price, I do think I want to go with ceramic because the brake dust is horrible with the factory semi metallic and even if I lose a little braking power since I dont go to the track I think it will be ok. So hit me up with suggestions please, and thanks everyone.
NewCamaroSSowner is offline   Reply With Quote
Old 10-11-2023, 12:26 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I just went with the AC Delco Professional semi metallic pads and their rotors when we did mine. To date they are pretty much dust free, and stop the car really well.
