![]() Drives: 2023 ZL1 M6, 2010 SS M6 Join Date: Oct 2009
2010 M6/TR6060 Oil - what's optimal these days?
I have 120k on it, probably should change it. I have no problems and are a heavy double-clutcher; but that's still a lot of miles on the oil now.
I'm asking for ideas on the best oil these days, hopefully from people who have put it in their car and driven on it for a bit. Thanks, |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I used the Amsoil ATF Multi Vehicle and I have been very happy with it, Temp stays low and shifts smooth.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() ![]() Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
I used royal purple, and have had zero issues. Shifts smoother I feel.
![]() Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
Mobil 1 Synthetic ATF
GPI Sales Consultant
Gonna get plenty of opinions on here. I've been very happy with the performance of Redline D4 ATF. Have run this for ~40k miles, very happy with the overall performance. It's been changed a time or two, since I run the car pretty hard at times, but every time I've dropped the oil I've thought it looked brand new, seems to hold up very well and I plan to extend my interval out some given those results.
Got a question about a GPI product? Feel free to shoot me a message! |
#6 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Redline D4 ATF x2
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
#7 |
![]() Drives: 2013 camaro 2ss 1le Join Date: May 2020
been curious if it would cause any harm to cut d4 with mt85, maybe .5-1 qt. ive been using d4 for the past almost 15k without issue, but i kick the crap out of my car and also live in the desert so im wondering if the mt85 would help with anything. plus i have a couple quarts lying around that ill never use for anything else.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners |
#8 |
It don’t come easy.
Redline here, as well.
#9 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
Gonna do mine next week, looks like Redline for the Win. 🏆
#10 |
![]() Drives: 2014 1ss camaro Join Date: Jul 2017
i used gm syncromesh. it usedto say on the bottle: does not break down. i believe it changed stock out when i first got the car. then was going to have libertys redo it with the fork pads etc. ended up going full bore with it but thats another story. when i drained it after about 15k miles it still looked like golden honey no bull s**t. i took a picure of it draining i coundnt believe it.
