Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 09-24-2023, 11:39 AM   #1
Robmnrd
Drives: 2013 ZL1
Decent low-profile Jack that isn't stupid expensive?
Honestly I don't even know which brand(s) to trust for this sort of thing right now.
I'm looking for a low-profile jack that will let me get the ZL1 up in the air. Quality is obviously first priority, but something that isn't stupidly expensive would be nice...
Recommendations are appreciated!
Robmnrd is offline   Reply With Quote
Old 09-24-2023, 02:37 PM   #2
Carpetguy
Carpetguy's Avatar
Drives: 2011
Daytona at Harbor freight has been good for me.
Carpetguy is offline   Reply With Quote
Old 09-24-2023, 03:22 PM   #3
gtstorey
I have an irontron from northern tool that is working well.
Old 09-24-2023, 03:30 PM   #4
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Not sure which HF I have (red one) but, works like a champ, no issues.
0stones0 is offline   Reply With Quote
Old 09-24-2023, 08:50 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
HF 3 ton low profile long reach jack less than 300 bucks I think.
Orange Krush II
Old 09-25-2023, 02:03 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
I have Bahco.
Old 09-25-2023, 10:25 AM   #7
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
I have a 2ton from HF. I think its Pittsburg
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
Old 09-25-2023, 03:59 PM   #8
Robmnrd
Drives: 2013 ZL1
Awesome, I appreciate the input guys. Sounds like there are many options that will work for me.
On the other end of the spectrum - are there any brands ya'll would suggest I avoid no matter what?
Old 09-26-2023, 07:18 AM   #9
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
This is the current version of what I have. I got it at Northern Tool under Arcan's Blackline label. It was under $250 back then and I used the NT 20% off coupon they send all the time. It's no longer on their site. It's pretty well made, maybe that dual plunger pump has something to do with it.
https://www.amazon.com/Arcan-2-Ton-S.../dp/B007G83T16
I've had a couple HF jacks and they never failed but were a bit harder to work with. I did have to put wheels on one. I have a Ranger long reach that lifts 31" for my 4x4 and I broke the piece that pushes the pump plunger. Summit replaced the jack. Don't understand why you would make that part from cast iron, and now I have to be a little more gentle with that jack because I know that piece can break. I hate having to baby tools.
Old 09-26-2023, 09:35 AM   #10
SlowLS1
SlowLS1's Avatar
I use this one and it is pretty low and still gets plenty high enough.
SlowLS1 is offline   Reply With Quote
Old 10-20-2025, 12:20 PM   #11
b4wheeler
b4wheeler's Avatar
Drives: 2011 Camaro 2SS Vert
Back up Top
Question:
Does the Quick Jack fit under a lowered 5th Gen?
I cannot get a regular jack under, so I have had to purchase a pair of wheel jacks to get it up so that a jack will actually fit under it.
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
b4wheeler is offline   Reply With Quote
Old 10-20-2025, 06:46 PM   #12
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I have to drive mine up on a board to get the quick jack under.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 01-12-2026, 03:53 PM   #13
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Ditto. I use a HF aluminum low profile. Unless you have a garage stay away from the steel ones. They are just too heavy to carry around.
Rainbow1616 is offline   Reply With Quote
Old 01-12-2026, 06:38 PM   #14
FASTFATBOY
Drives: 2013 ZL1
Buy the smallest Daytona aluminum jack at Harbor freight, used one for years and it just won't die.
Make sure you take a chock for the wheels with you.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
