Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 09-27-2023, 09:12 AM   #1
SlowLS1
SlowLS1's Avatar
Fluid extractor recommendations
Looking for a recommendation for a pneumatic fluid extractor setup. Don't want to break the bank on it, but really want something that "just works" without a lot of fiddling around.
I've been thinking about this one.
What are you guys using?
Thanks,
Brian
SlowLS1 is online now   Reply With Quote
Old 09-27-2023, 09:34 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I use a stainless turkey baster that has a silicone bulb, but I only use it for brake and clutch fluid.
I've never had that tool, but I have had pretty good luck with OEM tools for jobs I only do occasionally.
Edit: I picked up a 300ml syringe on AliExpress for $2. Works pretty good. Would not use it for gear oil.
Old 09-27-2023, 11:52 AM   #3
SlowLS1
SlowLS1's Avatar
I've not used much of the OEM tools, but haven't really seen anything bad about them. Reviews on that unit aren't terrible. Appreciate the feedback
Old 10-31-2023, 07:19 AM   #4
SlowLS1
SlowLS1's Avatar
Just an update. I bought the OEM Tools fluid extractor. It is a well built and seems to work very well. I tested it on a gallon of water and it vacuumed it out with ease and was surprisingly quick.
I am using it with air, and is a bit noisy. That is the air exhaust, and no fault of the tool.
Highly recommend
Old 11-05-2023, 05:16 PM   #5
SlowLS1
SlowLS1's Avatar
Finally got an opportunity to use it. Drained the auto trans and didn’t spill a single drop.
Very happy with the purchase!
Old 11-06-2023, 10:14 AM   #6
CamaroCracka
