Old 09-28-2023, 10:39 PM   #1
AJ54
Drives: Camaro ss 2010 / Caprice 2013
I need a help SS LS3 overheat
Hey y’all, so I recently replaced the thermostat to MotoRad, coolant temp sensor, and the coolant, The fans work great. So basically my car overheat after a ride when i shut it off for 5 minutes or longer it goes above 221Celsius and some times go above 221, wont start as usual and goes into safety mode the service StabilityTrak notification in the cluster, won’t crank like when it’s cold or at operating temperature, any thoughts cause I’m frustrated and confused?
Camaro ss LS3 2010
Operating temperature/// 178~208
AJ54 is offline   Reply With Quote
Old 09-28-2023, 10:52 PM   #2
gtstorey
221 degrees Celsius is 430 degrees Fahrenheit.
Old 09-29-2023, 02:42 AM   #3
Vicster
Drives: 13' ZL1
So what is the engine temp. when driving? Did you burp all the air out of the coolant system? Are you running 50/50 mix coolant? Has any type of leak fix been added to coolant? Has the coolant added always been dex-cool? Some coolants mixed with dex-cool turn into gel! Do you have headers? could be heat soak. Also if temps rise when engine running and car parked it is probably your water pump (impeller) issue. Stock thermostats start to open @ 195 degrees. @ 221 degrees f. car should start and run fine, it maybe a different issue. Have any of your ground wires been loosened if yes, check them.
Vicster is offline   Reply With Quote
Old 09-29-2023, 06:30 AM   #4
AJ54
😂😂 I meant Fahrenheit
Old 09-29-2023, 06:39 AM   #5
AJ54
When driving hard wont go above 201 F, yah sure i did burp the air, new water pump, Mercedes coolant Antifreeze50/50, no leaks at all, motorad thermostat, stock headers.
Old 09-29-2023, 10:46 AM   #6
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Check for air in your coolant system. Coolant has to be replaced under pressure to assure that air won't get into the system. Air in the system is a common cause for overheating.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 09-29-2023, 07:16 PM   #7
gtstorey
Stock setting doesn’t have fans cut on until much higher than you expect, low is something like the 221 you are seeing and high is about 227. I started troubleshooting mine the first time mine got into that range, but it’s how it’s designed.
Old 09-30-2023, 01:06 AM   #8
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Originally Posted by AJ54 View Post
���� I meant Fahrenheit
221 F is 105 C,it is normal.
wont start as usual and goes into safety mode the service STABILITY TRAK notification in the cluster, won’t crank like when it’s cold or at operating temperature, any thoughts cause I’m frustrated and confused?
Hot start issue : battery,ground,starter.
Old 10-01-2023, 10:19 AM   #9
AJ54
But is it normal to overheat to this point?
Okay does the bad starter a reason to turn on the StabilityTrak notification on the cluster?
Old 10-01-2023, 10:23 AM   #10
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
What shape is the battery in?
0stones0 is offline   Reply With Quote
Old 10-01-2023, 02:09 PM   #11
chevy pilot
It is not overheat in 221 F. (Boiling is near 245 F)
No,it is usually caused by low voltage in starter.
Old 12-02-2023, 08:51 AM   #12
Skelly
EMT NY
Skelly's Avatar
Drives: 2011 Chevy Camaro SS White
Sensor
Camaro ss LS3 2010
Obviously the temp is being exaggerated by the bad sensor which is a known issue. Your PCM does not know the difference so it triggers the results. Please change the $14.00 sensor and inspect the wire coming off it for broken ends, heated terminal clips the works. Follow it back to the harness and make sure there is no other issues. Unroll the protective plastic surrounding the wires and if it crumbles..replace it.
Sean
Skelly is offline   Reply With Quote
Old 12-04-2023, 02:14 AM   #13
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm with you on this one. Get the battery tested before doing anything else. And sometimes when they check the battery and say it's good it still can be bad. If it's more than like three years old, you might just want to replace it. Also, one more thing to do is add the extra grounds in the trunk and the chassis.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 12-04-2023, 01:14 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ Yes sir. This is the most common issue with a hard start. Your coolant temps are on par for normal running.
#ls3, advice or opinions, help me, overheat, problems
