09-28-2023, 11:48 PM | #1 |
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
6L80 Fluid Pan
Could anybody advise, what is the difference between 24222657 and 24297104 ? Both are in the GM catalog. 24297104 is slightly more expencive.
How many magnets in the fluid pan ? Thank you !
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
09-29-2023, 04:37 AM | #2 |
Looking at Rock Auto description, the only difference is that 24297104 comes with what they call a "drain plug". However, that looks like the fluid level check plug to me.
Doesn't look like either one comes with the magnets. 24222657 - https://www.rockauto.com/en/moreinfo...t=8546&jsn=735 24297104 - https://www.rockauto.com/en/moreinfo...t=8546&jsn=727
GPI 416 w/Custom GPI Cam, GPI Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
09-29-2023, 06:53 AM | #3 | |
10-01-2023, 12:06 PM | #4 |
You could always call them and find out what the difference is in them.
10-01-2023, 12:18 PM | #5 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
There are a lot of different oil pans for 6l80e transmissions. They will probably pretty much all interchange onto the trans but only the 24297104 is listed for the Camaro.
