Old 10-02-2023, 06:45 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Brake/clutch fluid flush
I just purchased the motive products speed bleeder. Should I flush the brake fluid first, or start with the clutch first? I have a speed bleeder for the clutch.
Is it as easy as pressurize the pump, and open the speed bleeder for the clutch?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 10-03-2023, 07:28 AM   #2
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I would strongly recommend moving the clutch fluid to it's own reservoir, as that tends to contaminate much faster than the brake fluid. Then they can be maintained separately, as needed. For me, I use a remote bleeder under the hood for the clutch hydraulics, which has a 1-way speed bleeder on it. I crack that, and drain it to a temp catch can, and then cycle the clutch a few times till the reservoir it pretty low. Then I clean the reservoir out as best I can with a towel, and then fill it fresh, and cycle the clutch some more. I repeat that several times to get fresh fluid throughout the system.
In the absence of a stand-alone reservoir for the clutch fluid I don't know that the order matters much. I'd probably go after the clutch first, since that's the dirtiest part of the system.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 10-03-2023, 09:39 AM   #3
RupertPupkin
Thanks. I was contemplating on getting the reservoir, but I do t really track the car. More puttin around town or the occasional Mexico pulls.
730whp: 630Trq
Old 10-03-2023, 10:23 AM   #4
gtstorey
Not sure the separate reservoir really has anything to do with tracking or not tracking the car.
Old 10-04-2023, 07:10 AM   #5
acammer
acammer's Avatar
IMO, a remote reservoir and remote speed bleeder on the clutch hydraulics are great additions to any enthusiasts car, be it just a fun cruiser or a track warrior. The remote reservoir gives you the ability to easily monitor the clutch (and brake) fluid independently. For the conditions my car sees, I tend to pollute the clutch fluid much quicker than the brake fluid, and so with the remote bleeder and reservoir it's easy to maintain that separately.
These cars have somewhat of a reputation for clutch problems, but really that's pretty much all related to the hydraulic system. Anything you can do to improve that system and it's serviceability helps mitigate that, and is a win in my book.
Old 10-04-2023, 01:34 PM   #6
RupertPupkin
Don't really beat up on the car.
I know on my Z, the clutch stuck to the floor during hat shifts. Fluid was clean.
730whp: 630Trq
