Old 10-05-2023, 07:16 AM   #1
SS ICE 10
Drives: 2010 Camaro SS
Unable to find power steering hose - HELP!
Hello,
Currently sprung a hell of a leak on the power steering lines and I’m unable to find one dry rotted hose leaving me in the dust here. Does anyone have access to a part# 92249335 or equivalent. Thank you!
SS ICE 10 is offline   Reply With Quote
Old 10-05-2023, 09:31 AM   #2
gtstorey
Few Options.
You might find a local hose shop that can make you a serviceable replacement, but probably won't be the exact same.
Since this is the low pressure side, you might be able to cut the metal lines and find a compression style coupling to swap it to AN/fittings. Several of us have done that on the transmission cooler lines.
Although it shows discontinued, a dealer might be able to find it as NOS on someone's shelf.
Junk yard
Old 10-05-2023, 12:55 PM   #3
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
If it's the low pressure side you can cut the metal line and put a slight flair on it ,clean the rough edges ,and use some rubber fuel hose . Slip the hose over the flaired end and hose clamp. I've done this many times and never had a problem. Don't flair it like normal flair ,maby half that ,it's just added security that it doesn't come off !
Ps. You could even use steel braided fuel hose for added security!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
Old 10-05-2023, 02:09 PM   #4
SaReNi
Drives: 2012 SS
these people can make pretty much anything you would need.
https://www.amazonhose.com/
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 10-05-2023, 05:21 PM   #5
roh
Drives: 2013 ZL1
A great option, but I always use transmission cooler hose. Better compatibility with p/s fluid.
roh is offline   Reply With Quote
Old 10-07-2023, 06:53 AM   #6
SS ICE 10
Reached out to them via phone / email.
They don’t seem to be too interested.
