Old 10-06-2023, 05:24 AM   #1
FloCamaroSS
Drives: 2015 Camaro SS L99 Automatic
2015 Camaro SS What Engine Block is interchangable?
Hello,
im from Europe and having some trouble with my 2015 Camaro SS 6.2 Automatic with the L99 Engine.
I have a broken cylinder (crack) and it cant be repaired (crack is also in the block itself).
So now im searching for another Option.
Can you please help me out what 6.2 engine block is intetchangable with my current L99 Block?
I want to remove dod so i can remove the crapy active lifters.
I could get an LT1 Engine out of a C7 but dont know if i could use that block/heads with my Camaro parts?
I know the lt1 has dry sump but if my oil sump would fit it maybe could be changed to wet sump like the L99 has.
The main problem is that thetr is no L99 engine avaiable in Europe - i cant find a used one.
Thanks alot for your help!
Regards,
Flo
FloCamaroSS is offline   Reply With Quote
Old 10-06-2023, 05:32 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Originally Posted by FloCamaroSS View Post
Hello,
Regards,
Flo
Any LS 6.2 will work iron or aluminum, dod block or LS3 based.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-06-2023, 06:47 AM   #3
SlowLS1
SlowLS1's Avatar
L99, LS3, or L94 blocks would work. Those are all Gen IV motors. LT1 is Gen V and not compatible with your other existing components.
I would buy an LS3 crate motor and be done with it. No more DOD and all new parts that your existing components will work with.
SlowLS1 is offline   Reply With Quote
Old 10-06-2023, 08:16 AM   #4
jeff657756
Drives: 2014 SS 1LE
Any gen IV engine will work.
jeff657756 is offline   Reply With Quote
Old 10-06-2023, 09:30 AM   #5
gtstorey
with tuning
Old 10-07-2023, 04:51 PM   #6
FloCamaroSS
Would an L92 empty block also work with my L99 internals?
Old 10-07-2023, 09:51 PM   #7
SlowLS1
SlowLS1's Avatar
It will work fine.
Old 10-19-2023, 07:23 AM   #8
FloCamaroSS
Would an complete rebuild L92 engine also fit with all my camaro stuff?
Its an complete rebuild engine block including heads from the L92 and i could get that engine here in Europe.
Thanks for your help anf answers.
Regards Flo
Old 10-19-2023, 10:27 AM   #9
gtstorey
Just a quick internet search would indicate that the L92 had variable valve timing but only early ones had cylinder deactivation (DOD/AFM). If you can't turn off DOD in the tune due to emissions requirements, you would have to replace the cam and DOD components on the L92 with L99 parts.
Pretty much all of the LS engines will work, but probably none are a 100% drop in. You are going to have to research what changes you cam make in Germany.
Even if you have a different series of engine that has all of the required "features" they may still need tweaking to make them function 100% (especially in the tune) and again is that allowed in Germany.
