Old 10-07-2023, 09:19 AM   #1
ForgotUsername
Drives: 2010 Camaro RS LT2
2010 v6: why can't i find rear shocks/struts??
I'm preparing to replace all shocks and struts. The front replacements I easily found and purchased as Monroe quick struts (shock/strut + coil spring assembled as one) but for some reason I can't find a similar loaded strut assembly for the rear from ACDELCO or Monroe (the only two names I was expecting to buy from).
Are there any brands that you can recommend for rear shock/strut/coil spring assemblies? I was able to find what I need offered by:
  • FCS
  • Duralast (autozone)
  • TRQ
  • Truedrive
Or if you've got another brand in mind? Consider that I'm really only interested in a reliable, OEM-type loaded strut... and less interested in specialty stuff like adjustable or parts focused on high performance/racing. It's my daily!
My car:
2010 Camaro LT2 RS v6
185,000 miles
ForgotUsername is offline   Reply With Quote
Old 11-15-2023, 12:00 AM   #2
Rob99
I’m Magik a physco dog
Rob99's Avatar
Drives: '15 1LT/RS & '23 3LT/RS
Rock Auto has both FCS & Monroe as OE replacement choices.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe.
Previous:
2015 1LT Ashen Grey
2016 1LT Blue Velvet
My entire life has been 'A Midlife Crisis'
Rob99 is offline   Reply With Quote
Old 03-15-2024, 10:29 PM   #3
Crystal_Red_SS
Crystal_Red_SS's Avatar
Drives: 2012 Crystal Red Tintcoat 2SS/RS
I would read up on FCS before buying them.
And I have never been a fan of Monroe stuff, based on experience with that brand on another vehicle.
I'm about to replace my front strut mounts due to aging rubber and deterioration and might as well upgrade the front struts that are 12 years old but have low miles. I chose the Koni orange STR.
Good luck with your choice.
ADM cold air intake with scoop, Solo Mach XL catback exhaust, custom tune, Stainless Power LT headers, RX catch can in Crystal Red Metallic
Custom Grind Cam 222int 230exh .601"/.608 116*+4, TSP 25% UD Pulley w/ ACC Serpentine Belt, 160* Thermostat, Melling High Pressure Oil Pump,LS3 Conversion,C5R Timing Chain,Amzoil ZROD 10W30,NGK TR6 Spark Plugs, Professional Stage II Cylinder Head Porting Service (360+ CFM), Install by 510 Race Engineering
445 RWHP, 419 ft/lb tq
Crystal_Red_SS is offline   Reply With Quote
