Old 10-07-2023, 09:07 PM   #1
Marknbacon
Drives: 2015 camaro SS
SS brake cooling ducts?
So I have a habit of “spirited driving” and as a result, my brakes tend to get a bit warm.
I would like to put some brake cooling ducts on my SS, but the only readily available option I see is the root-fab duct for the 12-15 ZL1. I have no special appearance package on mine, it’s just a plain 2SS.
Has anyone adapted these to a regular SS? Mine is a 2015.
Thanks!
Marknbacon is offline   Reply With Quote
Old 10-08-2023, 07:18 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I set up ducts before I went to Sebring the first time. It still burned up the brakes. Money and time better spent is the ZL1 front brake set up and you probably won't even need ducts.
Old 10-09-2023, 11:49 AM   #3
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
I made my own brake ducts with parts off Summit Racing.
The factory ducting under the crash bar had large block-offs that I cut into and fit a couple air intakes in and routed some tubing into the wheel well.
It isn't "properly" routed straight to the disk/caliper, they just fill the wheel well with fresh air and I have front wheel wind deflectors to help pull that air through.
It seems to get the job done!
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 10-09-2023, 03:22 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Nicely done, that looks pretty cool and functional to me!!
