10-21-2023, 06:56 PM | #1 |
Drives: 2017 Camaro zl1 Join Date: Oct 2022
Help Please - Remote Start Failure
Hi everybody,
My cars remote start randomly went out. I've checked everything from the battery, to changing the batteries in both fobs. I've done most of the typical fixes I read about, I have no code on the dash, nothing that I can that would indicate an issue, I've made sure the hood is closed, etc. When I click the lock button, car locks. When I go to do the remote start, I double tap the start button and the car doesn't do anything. Doesn't even attempt to turn over. No clicks in the engine, not lights flash on the rear. Just nothing. Curious on if anybody has opinions on this. This issue happened after I swapped out my sidemarkers. It was weird because I replaced them, started the car to ensure they were working. About a week later, the remote start stopped working. Any help is appreciated, thanks! |
10-21-2023, 09:19 PM | #2 |
Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
Hello,
Doesn't one have to actually *hold* the start button, until it starts? That's how it works with mine, which admittedly is not a ZL1 and is a year older.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K |
10-21-2023, 11:13 PM | #3 | |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
10-22-2023, 10:13 AM | #4 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
This sounds like it may be the issue, unless the reference to a double tap was just a typo in the description of the problem. Double tap is for the trunk button, but the remote start button gets held down (worked this way for both my '16 and '21).
10-22-2023, 10:23 AM | #5 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Yeah, you gotta RTFM
10-23-2023, 03:05 AM | #6 |
Hey fam, apologies on the late reply. I didn’t realize I don’t get notifications for posts. I’ve just normally done a double lock, double tap w/ maybe a small hold on the remote start and it starts. For some reason that process no longer works. Will check suggestions and report back.
I tried using the app, but it doesn’t work without an onstar subscription. |
10-23-2023, 03:10 AM | #7 |
Had to google what “RTFM” means. Seems we’re just turning anything into an acronym these days.
To provide some more context, I’ve had the car for almost a year. Never had any issues and have remote started it tons of times. This just randomly happened and stopped working. Better context for you or AITA? |
10-23-2023, 07:36 AM | #8 |
Drives: 2022 Camaro 2SS 1LE Join Date: Jul 2022
Mine I have to Hit the lock button once and then hold the start button for 3-4 seconds.
10-23-2023, 09:50 AM | #9 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Mine is intermittent from inside the house, sometimes it starts and sometimes it doesn't and all the conditions are the same.
10-23-2023, 10:10 AM | #10 |
Drives: 2016 1LT 'Vert Join Date: Feb 2022
Remote Start inhibit
Even though the FOB is sealed the contacts and buttons can get sticky causing intermittent operation. In your case I'm wondering if the buttion was "sticky" enough to see the double tap as a single long press. Maybe the temperature has changed or the debris has moved enough to now register the double tap as a double tap. Did you confirm that when operating the remote start per the manual, that it actually works?
other RS inhibitors are Oil Life monitor percentage, oil pressue, unlatched hood, too many concecutive remote starts (you get only 2), vehicle not in Park (gm has had issues with the selector sensor), the "spare" FOB is in the vehicle. I'm sure there are others and all of these may not apply. Some of thes may not provide direct feedback to the operator that they are inhibiting Remote start. |
10-23-2023, 11:36 AM | #11 |
Put a fresh battery in my primary fob. 1 tap of the lock button, 1 tap & hold of the push start button, fired right up. Not sure what was going on. Like I said I've had the car for almost a year and never had any issues with the remote start until now. Nonetheless, I appreciate everybodys help and input
10-24-2023, 10:34 AM | #12 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
10-24-2023, 12:17 PM | #13 |
Mine wouldn't start standing right next to it this morning. Other times I can be inside and upstairs and it hits. Car is in park. The only variable I could possibly see is the eBrake on or off.
10-25-2023, 04:03 AM | #14 | |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
This The sequence for most remote starters is hit lock, then start with a long hold. I have noticed If you’ve moved the car, for example pull it out of the garage and shut it off without driving it sometimes it will not remote start until it senses you’ve travelled a distance, some sort of a reset I guess. The same thing applies with my truck |
