Old 10-23-2023, 11:04 PM   #1
Stevoss10
Drives: 2010 chevrolet camaro ss
Question 2010 ss limp mode
Allright so I'm new to working on my car so I'm trying to learn things, but anyway I have 2010 ss it's been going into limp mode for over a year I've throwed money and parts on it that buddies or stuff I've read about, and seems like I'm in same position. So I've replaced throttle body, gas pedal, fuel pump, maf, map sensors, plugs and wires and more. I have no codes till goes in limp mode and then got anywhere from 4 to 6 codes (p0651 5v ref) usually always but it's different other times (p0122, p2135,u0109,u0073, p0430) I've had cats removed and put non foulers on oxygen sensors but it was going to limp mode before I did all that. Just bought a diablo sport tuner and car runs alot better but still limp mode. Any help or something to check would be greatly appreciated
Stevoss10 is offline   Reply With Quote
Old 10-24-2023, 01:56 AM   #2
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
I was way off, didn't read that you already done all that. sorry about that.
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Last edited by Infidel67; 10-25-2023 at 12:03 AM. Reason: Removed for being a dummy
Infidel67 is offline   Reply With Quote
Old 10-24-2023, 08:47 AM   #3
gtstorey
You have a problem that is affecting the 5v reference voltage. This 5v is shared by multiple sensors and that 5v can also show up as a DTC on any of the shared sensors.
Old 10-24-2023, 05:12 PM   #4
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
You need a scanner for this diagnostics, Disconnect all the sensors on the 5v2 reference circuit. Unplug the Accelerator Pedal Position Sensor (APP), the Crankshaft Position Sensor (CKP), the brake booster vacuum sensor, the clutch pedal position sensor (if equipped), and the throttle body. Check for the 5 V reference voltage returning, Then u can plug in one at a time to see if you loose 5 V reference 2. Then u can chase that component/circuit. Also spraying a 5% salt water solutions helps with finding wiring issues. Good luck
Mouse330 is offline   Reply With Quote
Old 10-25-2023, 05:51 PM   #5
Stevoss10
Appreciate it guys, I'm gonna start messing with it this evening I'll let you know. Thanks again
Old 10-25-2023, 06:25 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Good luck sir!! Hope is is a simple deal..
5v refrence to circuit, limp mode, p0651
